Thread: Using Distilled Water to Mix Diamond Brite?
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Is this ok? I heard distilled water has a lower pH than R/O so was wondering if low pH would be harmful to mix Diamond Brite.
    Any feedback is much appreciated.
    Many thanks!
    Re: Using Distilled Water to Mix Diamond Brite?
    Distilled water should be close to pH neutral (7.0). Is may be slightly acidic due to the absorption of carbon dioxide, but not enough to matter. Distilled water can be used to mix concrete or cement. It can be beneficial when other sources of water have impurities, such as iron, that could adversely affect the quality or the aesthetics of the cement.
    Distilled water is actually used when making reference samples of concrete to compare with samples made using water of questionable quality.
    Support the site
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Thanks James. Much appreciate the info.
