Results 1 to 11 of 11
Thread: Testing after a storm
    Oct 2011
    New Caney, Texas
    414
    We just had storms move through here this morning, we had 2.75 inches in the rain gauge.
    I tested the PH and FC.
    Ph 8.2 very purple
    FC 6.5
    Yesterday it was
    Ph 7.5
    FC 6
    I guess its the rain that raised the PH, will this come down on its own or do I need to add some MA?
    Thanks
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    Jan 2011
    Richmond, Texas
    595
    Re: Testing after a storm
    We received about an 1.25 inches this morning and my Ph did not rise at all. It stayed right around 7.4 from the day before. Did you run your pump after the storm? I would make sure you run it, test again and then if it is still high I would add MA. BTW I didn't need to add any after the last big storm on 1/9 either. During that storm we had over 7 inches of rain.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    30,421
    Confirm your test results because rain should not have that much affect on pH. Nevertheless, if your pH is higher than 7.8, bring it down with muriatic acid. It will not come down on it's own.
    Oct 2011
    New Caney, Texas
    414
    duraleigh I retested and same results, I had started the pump as mentioned by Flippy so I just added the MA.
    I'm confused as I use a pool log that I got from Bama. I record my reading daily as I'm still learning.
    What could have made it go that high?
    Must be the BS content in those Texas rains...
    Sorry, being from NM I couldn't resist!
    J.Ollman
    18k gallon, in-ground gunite, attached spa, sand filter
    30,421
    Well, Pool monitor's idea may have merit ( ) but probably the most important thing is not to worry too much about what caused it.
    What's really important is that you tested and found the issue and know how to correct it. Bring it back on down and keep an eye on it...rain or not.
    Oct 2011
    New Caney, Texas
    414
    Ok, thanks again.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,014
    There's no way to tell without ALL the readings, but I will hazard a guess. You probably have high TA. Heavy rains - the kind that make it look like the pool is boiling - aerate it, which drives up the pH. As a consolation prize, the TA should be lower than it was.
    When I test after a good rain, I like to let the pump run at least an hour and do a good brushing with the wall whale to be sure the water is well-mixed.
    Oct 2011
    New Caney, Texas
    414
    Thanks Richard. I have the pump running now after adding the MA. I don't do a daily test of the other reading but as it has started to rain again here I'll run a complete test tomorrow and report back. My last complete test on 1/16/2012 was:
    Ph 7.5
    FC 6.5
    TA 60
    CH 120
    CYA 30
    Bor 50
    Temp 54
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    A hard rain always drives my PH up .2 or .3
    I always add some extra bleach if I have a chance if I know it's coming too.
    Dec 2011
    Gold Coast, Australia
    57
    I had the same happen here. Bucketing down for days. The overflow couldn't even keep up in the end so water was pouring over the side. While it was raining I googled the pH of rain water to guess the effect on the pool when it eventually stopped. Average rainwater pH seems to be 5 to 5.6 so I thought in theory it should come down a little if anything. When it stopped raining and I did my test and the pH has gone up from 7.5 to 7.9.
    When I thought it through I came to the exact same conclusion as Richard that the heavy rain had aerated the pool which caused the pH to rise. As Richard also suggested, my TA had gone down by about 20ppm. I assume that's just dilution. Shame because I just added calcium and cya the day before the rain started... I assume they will have been diluted down too.
    37000 litre, concrete, pebble, Viron P300 pump, Hurlcon VX7T SWCG, Viron CL-400 Cartridge filter, Solar heating, Pandora Smart Robotic cleaner
