Thread: Is piping damaged by chlorinators plumbed in the return?
    Automatic chlorinators such as inline puck feeders, liquidators, peristaltic pumps and SWGs are usually plumbed in the return line after all other equipment.
    I suppose that the piping between the chlorinator and the pool, possibly made of PVC or ABS, is subject to high concentrations of chlorine. Would it cause any damage to the piping (cracks, leaks) in the long term?
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Is piping damaged by chlorinators plumbed in the return?
    I would think not, as the concentration is not all THAT high. Its not like you are pumping 6% bleach through them anyway.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
