Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: How deep should be an inground pool?
    I have a 15' x 32' inground concrete pool which is 4.1/4' (1.30m) deep. It does not have a deep end, it is just flat. Sometimes, I wish I could be able to float in an upright position without having to bend the knees. That would require a depth of at least 7'.
    How deep is the deep end of your pool?
    If you were to build another one, would you build it deeper?
    Would you shallow dive into a 4' deep pool?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,983
    Re: How deep should be an inground pool?
    I've never actually measured my deep end. It seems to be 8 feet. It might even be 9. I wouldn't have a deep end if I were starting from scratch.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    I recently built mine from scratch. I went from 4 1/2 to 5 1/2. I wanted a social pool, and not a rowdy diving pool.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Dec 2011
    Murfreesboro, TN
    111
    Quote Originally Posted by RodrigoBRL
    I don't think there is a correct answer. Being a taller guy myself at 6'2" I had similar concerns so we went with a 4.5' shallow and a 7ft deep end. I couldn't imagine having an inground pool that was barely chest high but that's my personal preference. Different strokes I guess.
    22 x 36 In Ground Vinyl - 23K Gal - Saltwater - Tara Liner
    1hp 2-speed Hayward Super Pump, Hayward 6060 Booster Pump
    Hayward SwimClear C3030 Filter, Hayward 400Btu NG Heater
    Hayward Aqualogic PS-4, Polaris 280 Cleaner, ColorLogic 4.0 LED
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    As deep as you need to please you. That's kinda tongue in cheek, I feel it's personal decision. Our pool had a diving board before we purchased it, so our deep end is about 8 to 9 feet deep. Most people stay in the shallow end except when we're on floaties or jumping in. Really depends. I agree with those who've posted earlier.
    Dec 2010
    San Diego, CA
    1,137
    NO!!!
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,053
    Ours goes from 3.5 ft to about 4ft 8inches and is perfect for us. The wife has a metal knee and it is great for walking. I will never build a pool where I could not stand all round. We wanted a Spool ( Social Pool)
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Just to disagree with everyone, I would build a deep end, and make it as deep as I could afford and had space for; 12' sounds nice! It just depends on what you want.
    Aug 2010
    Dallas, TX
    4,052
    I like having a deep end, but mine gets deep too quickly, and I wish my shallow end was a little more shallow. I even think we'd like beach entry.
    Glass by the pool makes me shiver by the way!
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    I'm not certain how deep it gets (maybe 8 or 9ft?), but it starts at 3 1/2 feet. If I were to build it from scratch, I'd still go with a deep end. But I'd ditch the diving board and go a bit shallower, I don't need 8 or 9 feet to be able to float around upright or jump in.
    4 1/2ft to dive into? You are about the same depth as many above ground pools. I'd consider some of their guidelines. Regardless that's pretty shallow for people to dive into. I'd say, no don't dive into that depth its probably pretty dangerous.
    If I remember right, in high school, the diving blocks were in the shallow end and that was about 4 - 4 1/2 (I could be wrong that was like 20 years ago). However we were taught to dive for distance not depth for competition swimming.
    In the end, I'd recommend against it. Its just not worth the risks. Either way, people should always be careful when diving regardless of depth. Even at 8 or 9 feet you get to the bottom pretty quick when diving.
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Feb 2011
    Petaluma, Ca
    665
    I'm happy mine is 8', even though with the diving board 9' /10' would have been better. Shallow end is smaller the deeper you go though.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Mar 2007
    San Rafael, CA USA
    12,082
    Unless you are 8' tall, you don't need a 7' deep end to be able to float without touching the bottom. My pool goes from 3' to 6'. I'm around 5'11" and can no longer touch the bottom somewhere around 5' depth assuming my head is staying out of the water. For the purposes of being able to tread water without touching the bottom, 6' is fine unless you are very tall (i.e. 7' or taller). For diving, you would want a greater depth, usually around 8'.
    Thank you for the recommendations regarding safe diving. I was thinking about diving for distance, not depth, as Puffin pointed out. If I were to build it from scratch, I would build a 6' deep end so as to be able to float without touching the bottom (I am 5'10" tall).
    MattM's Avatar
    Jul 2011
    San Diego, CA
    299
    I think the answer depends on who is going to use the pool....if its just adults and no one is big on diving, than 4ft shallow end and 6ft deep end seems to meet most needs. If you're taller, make the shallow end deeper if you really want. If you have kids, I would think a real deep end of some kind is needed because honestly...when you're not watching, they're going to jump in and not always safely...and the older they get, the deeper the pool will need to be but you shouldn't need to go beyond 7.5ft, unless you have a diving board - in which case, you'll probably want 10ft+ for liability purposes. If you have young kids...or friends with young kids that will be swimming....4ft will be too high for the shallow end unless you're very carefully and ensure that anyone going in the pool is a good swimmer. Pools with young kids have 3-3.5ft shallow ends.
    24K gallon inground gunite/pebble sheen pool, 34'x16' 4-7.5ft deep, 750sq ft solar, pentair ultratemp, intelliflow vs+, ic60, intellichem w/ acid pump, quad de 100, intellibright 5g, intellitouch i5-3s with Screenlogic2, 3" primary piping - 2.5" at equip pad, auto switched deep heating and main returns, automatic safety cover w/ electronic lock and embedded recessed undertrack, sealed stamped concrete deck, dolphin deluxe 5, started up December 2011.
    We are building ours now as 4' 5' 4'. 17X35. While jumping in is entertaining, it is only fun for a short time. What is fun for hours is when you start doing things like playing sports. So we designed ours so we can play volleyball and basketball and have the whole pool to do it. Also we found that most people stay in the shallow end of pools so they can just hang out. This way people can "hang out" in the whole pool.
    If we could have made a bigger pool we would have done both, a 35ft shallow plus an L for the deep end for diving, but we didnt have enough room in the yard.
    The builder said you can safely jump into 5 feet. Just no diving.
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    May 2011
    Orange County, CA
    696
    Our pool has a shallow end around 3.5-4 feet and a 10-11 ft deep end. I am very happy that the deep in is that deep because there is a large rock waterfall next to the deep end. Since we have kids who like to jump off the rocks (regardless of our admonitions), the depth of the water allays at least some concerns. If there is an opportunity to dive or jump, kids will do it. It's best that there is a place for them to do it with relative safety. Diving head first into a shallow pool could be very dangerous and I'm sure this has caused numerous serious injuries. Yes, we should warn children to use the pool properly, but allowing them to dive into the deep end will minimize their urge to do something really dangerous.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    Nov 2010
    Calera, Al
    271
    Ours is 3-6 ft. I can touch at every point and people use the entire pool. It is just deep enough to be eitirely in the water with just your head out and still touch the bottom.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Nov 2011
    Magnolia Texas
    80
    Our is 9-1/2' deep. Dimensions are 42'x 18'. 28,000 gallon swg. We had a diving board until our insurance company threatened to cancel us when they came out and inspected our house.
    28,000 gallon salt water pool
    DE Filter
    Inground plaster construction
    1-1/4 hp pump with 1hp booster pump
    Feb 2011
    Petaluma, Ca
    665
    Quote Originally Posted by Boland01
    Weird, Before I put in my pool / diving board I called my home owners insurance (farmers) to ask if it would affect my rate. They said as long as it was installed in a pool that had the correct "diving profile" for a board that there would be no increase in my rates.
  20. Back To Top    #20
    Me and the kids love to dive, so I would never have a pool without a deep end. When teens get together they're going to dive into the pool, and if there is no deep end, that could mean trouble. But I never wanted a social pool, nust one for diving, doing laps, volleyball, and other pool games. We were kind of lucky cause my wife insisted on an L shaped pool, so we have a 16' by 40' shallow arm, and a 20' by 40' deeper end, goes to about 9' I think. But different strokes...
    Tom
    In gound vinyl L, ~41,000 gallons, Pentair Clean and Clear Plus 420 cartridge filtter, Pentair 2 speed WhisperFlo pump
