- May 3, 2007
- 17,002
- Plaster
- Hayward Aqua Rite (T-15)
Does the water volume in the irrigation pipe increase when the spa is running vs when the spa is idle?bpham said:I also did the test of filling the spa with water, without releasing the tank pressure, the water still went down and the irrigation pipe still had water coming out. If this is the case of issue with the jet's low flow, how do I fix it or try to fix it? Thanks.
During this test were spa valves set to spa only?
Does the water stop flowing out of the irrigation pipe when the water level is below the spa jets?
When you had the spa valves turned to the off position, did the spa still lose water?
Is the equipment pad higher or lower than the pool water level and if so by how much?
When you opened the filter bleeder valve and the water stopped in the irrigation pipe, where was the water level in the spa?
Sorry about all the questions but I am still not following your comments.
