Thread: safety - simultaneous acid + swg dosing?
    MattM's Avatar
    Jul 2011
    San Diego, CA
    299
    I created a new topic separate from intellichem for this question because I wanted to get a clear answer and because the question might relate to other equipment:
    The intellichem controls both acid and swg runs. By default, it will allow acid to be mixed while the SWG is running...it also warns that acid should not be dumped while liquid chlorine is being mixed and has a setting to force chlorine sources to shutoff when acid is dumped. I assume that this warning should not apply to an SWG or should it? Both result in chlorine and the intellichem runs an SWG at full power which means a non trivial amount is being added.
    I looked into enabling the force shutoff by default just for safety but it is causing issues...(interrupted swg runs do not restart for several hours later, and then can get interrupted again...)
    I have a question into pentair on this...but how much should I be worrying about this? Note that when acid is mixed, it goes into a dedicated canister which is slowly fed into a pipe just before the SWG. The pool builder left the default system simultaneous setting enabled when it was first configured.
    24K gallon inground gunite/pebble sheen pool, 34'x16' 4-7.5ft deep, 750sq ft solar, pentair ultratemp, intelliflow vs+, ic60, intellichem w/ acid pump, quad de 100, intellibright 5g, intellitouch i5-3s with Screenlogic2, 3" primary piping - 2.5" at equip pad, auto switched deep heating and main returns, automatic safety cover w/ electronic lock and embedded recessed undertrack, sealed stamped concrete deck, dolphin deluxe 5, started up December 2011.
    22,553
    Re: safety - simultaneous acid + swg dosing?
    At the flowrates and concentration in the stream it's fine to allow the acid dosing while the swcg is operating.
    The issue with other chlorine sources is that they may not mix as thouroughly as the chlorine the swcg produces and they would be injected in greater concentrations. That's the reason for shutting them off while the acid is being added.
