Results 1 to 7 of 7
Thread: Filter review?
    Oct 2010
    Temecula, CA
    122
    Filter review?
    Hi all,
    I currently have a non-working Pentair SWB 4000 48 sq ft filter that is not working and I need to replace it. I don't want to spend a ton of money since most of my cash is going into the remodel of my kitchen currently.
    I found a Pentair 2000 48 sq ft filter on craigslist.. What is the difference in the numbers? Is this something that could work for me temporarily until I am in a better position to replace my equipment?
    I was on here a few months ago when this happened and it was recommended I stay with the same size or go up... I am off to read reviews, just thought I'd stop by and ask you all.
    Thanks
    anne
    Temecula, CA
    16X32 (approx) 20k gal, DE filter, IG, plaster/pebble with diving board & slide
    Whisperflo pump; Pentair SMBW 4000 Series filter... that's all I know! Still learning....
    22,553
    Re: Filter review?
    The 4000 series has a fiberglass housing and the 2000 series has a stainless steel housing. I'd inspect the housing real well for rust and/or pitting before making a commitment on the metal one. The media area is the same but you'll have to replumb to make it fit.
    Jan 2012
    340
    Re: Filter review?
    If it's a good deal pricewise and the filter is in good shape, go for it. If the filter looks rough, steer clear. Those filters don't use the same grids as most DE filters do and if I remember correctly, Pentair isn't making those filters any more. You could end up shooting yourself in the foot in the long run. Personally, I'd stay away.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    Oct 2010
    Temecula, CA
    122
    Re: Filter review?
    Thanks for that. I really don't want to drop $800 etc for a new one but I guess this is enough to keep me away. I'd love to just replace the one I have since I have all the grids and I know how to use it... thanks again
    Temecula, CA
    Jan 2012
    340
    Re: Filter review?
    Is your housing cracked? What makes it non-working?
    Oct 2010
    Temecula, CA
    122
    Re: Filter review?
    It has at least one small crack on the bottom that is causing it to leak. It was not losing pressure yet but was leaking enough to be noticeable.
    Temecula, CA
    May 2011
    Orange County, CA
    696
    Re: Filter review?
    Is the crack in the bottom shell or is it in the backwash valve assembly? If the latter, you could probably replace it for not too much cash.
    http://www.poolcenter.com/parts_filter_ ... m_smbw.htm
    If it's in the bottom shell, it would make more sense to purchase a new filter.
    We have an SMBW2000 series (60 sq ft) and it works quite well. The stainless steel holds up quite well and it is quite ruggedly built. Contrary to comments above, I've had no problem sourcing parts for it, including new filter grids. You can find them here for a reasonable price:
    http://www.a1poolparts.com/-strse-677/P ... Detail.bok
    There are 8 filter grids, so I would suggest going with the kit if you decide to purchase the used one off eBay.
    You should also purchase a new o-ring for the unit. If it has the backwash option (e.g. the filter number would be SMBW2048 instead of SM2048), make sure the backwash lever moves properly. Seating the top of the filter can be kind of a pain, so I use gravity to help by filling the tank with water (after cleaning, etc) and then opening the backwash valve. I place the filter top onto the o-ring and the suction from the water flowing out helps to seat the top. Liberal application of silicone lube helps.
    I'm surprised that I cannot find new DE filters made out of stainless steel. I would think these stainless filters would hold up much better over time, esp. since they would be impervious to UV damage whereas a fiberglass unit would have problems with this. In any event, if it were me, I'd take a close look at the eBay unit and if it's in reasonable shape, get it. Like was said, you will need to replumb it because the inlet and outlet are a different configuration than the 4000 units. But, this shouldn't be too difficult.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
