Results 1 to 7 of 7
Thread: white smoke from the floor of pool
    Jan 2012
    Tampa Florida
    1
    I tried different things to keep my pool clear, but is not working, I run the pump 3 hrs a day I put chemical every week but when i brush the floor of my pool I noticed is a white smoke coming from the floor and make the water blurry. i don't know what to do.. it just making me crazy.
    Re: white smoke from the floor of pool
    Is the floor painted?
    Support the site
    Butterfly's Avatar
    South Carolina
    10,045
    It would really help if we had current test results. Here's what we need:
    FC - Free Chlorine
    CC - Combined Chlorine
    pH -
    TA - Total Alkalinity
    CH - Calcium Hardness
    CYA - Cyanuric Acid (stabilizer)
    Borates - (if you are using borates)
    Welcome to the forum
    You're done SLAMing when:
    Nov 2010
    Calera, Al
    271
    Is your pool a newly plastered pool? It would be helpful if you were to put your pool specs in your signature.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    I am willing to bet your pool is either painted or newly plastered.
    You may want to have a thorough read of pool school (big button on the upper right) to understand that just putting a set amount of chemicals in once a week is not the ideal way to maintain a good body of water that will make your pool last.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Aug 2007
    near the swamp
    806
    I agree with Lershac, but your pool could've elected a new pope.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Could be DE in the pool also. You should post up the specs on your pool along with the test results others have asked for so that you can get the help you're seeking.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
