Results 1 to 9 of 9
Thread: fighting dirt in the pool
    All last summer and this winter its seems i can never keep dirt out of the pool!!! My wife nags me because she thinks if i would have gone with a pressure side cleaner that it would stay cleaner (her mom and sister have them and they stay spotless with dirt). I opted for a robotic nitro wall scrubber, which i have been happy with. What causes so much dirt to get in? We live in the country and they farm around me do you think its dirt in the air that lands in the pool? I am using zeobright in the filter, could that be the problem? We have two returns in the steps and they always seem to have dirt on them, could the filter not be pulling the dirt out? Any ideas? If anyone needs more information to help cure this problem I can answer.
    Thanks
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    2 HP Hayward Super Pump with 25" Sand Filter Filled with Zeo Bright
    4 Pentair Deck Jets
    2 Hayward ColorLogic 4.0 Lights
    Diving Board
    Turbo Twister Slide
    Hayward Aqua Plus Automation with 2 Actuators
    100% DIY Build not 1 penny paid yet to build this thing!!!! = Lots of work and Long Nights
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: fighting dirt in the pool
    Quote Originally Posted by allybuck64
    This.
    When we had tremendous windstorms here a few weeks back, my pool got loaded with dirt. If you get dust on the windowsills, you'll get dust in your pool.
    Feb 2008
    Denton, TX
    5,061
    Living rural and being in close proximity to farming and ranching operations is certainly a recipe for dirt in the pool.
    Your robot will probably beat most any pressure side cleaner out there.
    That's why I went with a robot from the research I have done. It seems like its all the time for dirt, wind storm or not. Maybe i will plant bamboo around the pool to create a wall 20 ft high
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    30,426
    Since you have dirt accumulating at the returns, have you backwashed the filter?
    I back wash all the time, ill isolate the main drains and sweep towards the deep end let it pump for a couple hours then backwash. If I don't do a manual cleaning of the pool ill back wash when filter psi goes up 10psi. I know of one other pool in the area so I keep meaning to stop by to ask if they have a similar problem.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I live in a similar area, and do get dirt after windy days. One thing you might be experiencing is barely controlled algae. I've had it happen where the pool always looked dirty no matter how much I vacuumed. The water was clear and it never went green, but the bottom of the pool would quickly be covered with a brown film. By just being more meticulous in maintaining the chlorine level, the pool will now go for more than a week without looking dirty.
    Thanks ill try keeping the chlorine level up and see if that helps.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    Gotta believe it is either dirt or do you have a lot of tree and plant life around...My pool sits in direct sun all day...but our yard is surrounded by homes with lots of trees. I get pollen in my pool and like Richard says if you get dust on your window sills, or on your windshield of your car a lot...you get dirt on the surface of your pool...and if you don't filter that out somehow...You will get the dirt on the bottom. I put skimmer socks on the skimmer basket...and it keeps a lot from even entering the filter itself...But I still get it on the bottom as it sinks from the surface...the longer each day I run my pump the better it is...if the pool sits for a day even with the solar cover on...the dirt covers the bottom..
    I just vaccuume it up.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
