Thread: How to test Compool 3800 TS-5L temperature sensor
    adelman's Avatar
    Dec 2011
    Corralitos, California, U.S.A.
    23
    Anyone know how to test a Compool 3800 TS-5L temperature sensor?
    Are they resistive, and what would nominal resistance be at 60-70F?
    I'm getting an intermittent dreaded "Err1" on the Compool, and sometimes erratic temperature reports. I suspect the problem is the wiring between the controller and sensor getting wet, but before I attack it I wanted to try to isolate and test the sensor itself.
    Any idea how to test such a sensor for basic functionality?
    Mar 2011
    441
    Re: How to test Compool 3800 TS-5L temperature sensor
    There is a resistance chart somewhere but you can always swap it with, or compare it with the freeze sensor.
    20X40 30,000 gallon gunite pool
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Take it off and look at it. It may be split, or cracked. then you will know right away if its bad.
    Factory Warranty Station for:
