Results 1 to 7 of 7
Thread: akaCarioca's outdoor kitchen - looking for input
    Nov 2011
    Tampa Bay FL
    58
    Nice job!
    I am looking to build a small (8 ft wide) cooking area and have never heard of "welded aluminum frame" outdoor kitchens.
    One builder offers this:
    - Welded Aluminum Frame, Dryvit "TerraNeo" on Cabinets
    - 3cm granite countertop
    - Fire Magic refrigerator model #3590A
    - AOG Built in 30x18 grill model 30PB-00SP, with optional infrared burner
    - AOG storage door model 17-24-SD(under grill)
    - Fire Magic Legacy enting Panel model 5510-01
    - 15 x 15 under mount bar sink and faucet
    Any advice regarding traditional concrete vs welded aluminum frame? I have the concrete being poured on my pool tomorrow and need to make a decision on the kitchen this week.
    Here is the draft:
    15x34 in ground, 16.5K gallons, Emerald Isle pebble finishing
    Pentair IntelliFlow VS-3050 pump
    Pentair Quad D.E. filter
    Pentair IntelliChlor
    Pentair IntelliBrite 5g LED light
    Pentair Great White Vacuum cleaner
    Riles_J's Avatar
    Nashville, TN
    218
    Re: akaCarioca's outdoor kitchen - looking for input
    Nothing at all wrong with welded aluminum. I have seen outdoor kitchen made with block, wood, metal studs and aluminum and they will all work if constructed properly. As a DIY'r I was more comfortable working with the metal studs, but that just a preference.
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,068
    Do you have an idea of the cost to built your outdoor kitchen including the appliances? The reason I asked is because you might want to look at a pre built one. I have one and love it. Look at this link http://www.paradise2u.com/about.html
    These outdoor kitchens are made with Welded Steel frame. We have one and we love it
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Jan 2011
    Riverside, CA
    352
    The Firemagic Frig is fairly expensive. From what I have read, it is just a Danby with the Firemagic logo.
    I'm still undecided on my frig and all the rest of my stuff is Firemagic. I'm not going to pay an extra $300, just so the Frig says "Firemagic"
    40x20 Free Form IG Pool (aprox 29,000 Gal, 140 Perimeter, depth 3'6"-7', Baja Shelf, 8x8 Free Form Spa) - Gunite Shell, Pebble Plaster Finish, Poured Concrete Coping - 3 Deep Heat Returns - Jandy LXi400 Gas Heater (400,000 Btu) - Jandy Variable Speed Pump JEP 2.0 - Jandy CL 600 Filter - HASA Liquidator - Jandy PDA 6 w/ Remote - 4x Jandy WaterColors Pool LEDs - 48" Gas Fire Pit - 6x Gas Tiki Torches - 12'x15' U-shaped BBQ Island (Firemagic Equipment)
    http://www.troublefreepool.com/new-p...ca-t28413.html
    blancawilliams's Avatar
    Feb 2017
    Toronto, Ontario
    1
    It looks nice!
    Aug 2017
    UK
    9
    You folks are very lucky to live in such warm weather in the US in the first place! No point in investing in those over here.
    The welded aluminium would be good too.
    That's Mr T to you...
    Living it up with my new install in sunny ol' blighty!
    Work as a plumber in Bristol
    Jun 2016
    Parsippany, NJ
    21
    Nothing wrong with building the kitchen out of metal framing and board. Ours is built from aluminum studs and durock cement board (same stuff you'd use under a bathroom tile floor, for example.). After it was all framed out, they just applied a cultured stone veneer to it. Looks great and much lighter weight than a traditional stone build. That was a big deal, since we did this right on our deck. Here is ours - you'd never know it was metal studs and cement board!
    16x32' inground liner, ~24k gal; Brilliant Wonders LED waterfall. Pentair Whisperflo/Clean&ClearPlus520/IC40 SWG/MasterTemp 400/IntelliTouch i9+3s/2x MagicStream laminar jets. Hayward Universal ColorStream (long story!). Aquabot Optima RC cleaner FTW!
