Results 1 to 8 of 8
Thread: Pump humming; not turning
    Split from the pump-humming-not-turning topic. Bama
    I am having the same problem, pump hums won't turn on. Questions: i have a northstar 2hp pump, how do I spin the impeller? Do I take the lid off of the basket area when the pump is on?
    I cannot get the cover off of the motor to check the capacitor, how do I do this? I'm not sure how to get to the motor.
    Thanks for any help.
    25,000 gallon saltwater pool with raised spa, Hayward de filter 6020, 2 hp pump, aqualogic PS-8 Controls - Dallas, TX
    22,553
    Re: Pump humming; not turning
    Do not take the lid off the basket when the pump is on.
    If there's not a 'bump' on the side of the motor then the capacitor is under the back cover. If you're not confident in testing the motor yourself I highly suggest you take the pump out and take it to a pool or motor shop and have them check it for you. We don't want you getting hurt.
    There are usually a few screws on the back cover that hold it on. Be sure the power is off before removing the cover.
    There is not a bump on the side of the motor. IT looks like there is a 'cap' (for lack of a better description) that slides on the end of the motor, I'm assuming from pictures that under this is where the capacitor would be. I'm fairly handy, I know how to check the capacitor, I just can't figure out how to get the cover off; there are no screws, bolts or anything on the motor to remove the cover, does it slide off?
    22,553
    All I've ever seen either have screws in the side of the cover or use the motor through-bolts to hold them on.
    Aug 2011
    Metro Atlanta, Georgia
    161
    It sounds like an AO Smith, like the one on my late Superpump. I don't know that much about electric motors, so I will defer to Dave, but mine had a tight cap, on the end, held on by two (?) screws, that needed a few taps with the handle of the screwdriver to loosen up to get to the wiring.
    Agarza, maybe you could locate a pic? If I recall correctly, (which might be doubtful), there are only a few motor manufacturers for a lot of pump makers.
    My cement pond is a 36K gunite 20X40 built in mid 1960s, Hayward S244S filter, Aquarite SWCG, Jandy 1.5HP 2sp, TF-Test kit and Nitro Wall Climber
    Aug 2007
    near the swamp
    806
    here we go, this is on one of my display cutaway super pumps
    cap is on the left, held on by a metal bar clamp that's screwed down with a 1/4" nut/screw
    side view
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    If a picture is worth a thousand words. Here a video that is worth a few thousand words. http://www.youtube.com/watch?v=ZEIv5ClLqXg
    Jan 2012
    340
    Northstar motors are a little different design than most motors, including the one in that picture. The end cap is a plastic half circle and the 1/4" bolt is in the middle if I remember correctly. Take that off and the capacitor and shaft will be exposed.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
