Thread: Water above the skimmer with pump on...problem?
    Hello, I'm still in my first year of inground pool-ownership & have a newbie question....
    It's raining a lot down here in NW Georgia. Is it okay if the pump comes on (we have a timer) if the water gets above the skimmer? Or should I leave work to go home and drain the pool some? Thanks so much!!
    In-ground pool owner in NW Georgia: 18 x 37 IG Grecian vinyl pool installed April 2011: 27k gallons, Hayward SWG auto-cleaner with booster pump, Hayward Aquarite T-15 Salt System with timer freeze controls, Hayward Aqua Plus, 1.5 HP Tri-Star pump, 48 sq. ft. D.E. filter.
    22,548
    Re: Water above the skimmer with pump on...problem?
    It'll be fine. The skimmer won't work very well but it's not going to hurt anything. You can drain it this evening if it doesn't have an overflow.
    Now stop worrying about the pool and get back to work!! JK!
    Thank you Bama. I soooo appreciate this forum and the help I've received!!
