Thread: Cold this morning, solar valve opened?
    jjslinger's Avatar
    Sep 2011
    Santa Rosa, CA
    97
    Hi Everyone,
    Something weird happened this morning.
    A couple months ago, I shut off the solar heating in the Easytouch system, and opened a hose bib at the bottom of the solar panels to drain them, as instructed by my builder (I notice that many of you have a vacuum release valve, and a small hole in your solar valve, but my system simply has a hose bib at the bottom of the panels for draining).
    This morning at about 7 AM, it was very cold for around here, about 23F, which is the coldest it's been since the pool was completed in September. Apparently, the pump freeze protection turned on, which I would expect, but also the solar valve seems to have opened, which I would not expect; water had exited the hose bib, and the pool level was about 1/8 inch lower than normal.
    Does the Easytouch system open the solar valve for freeze protection? Or, did something else happen?
    Don
    16K gal IG 16'x28' pebble since 2011; Pentair Easytouch; Sta-Rite Intellipro VS pump; Sta-Rite 400 sq. ft. cartridge (System 3); 6 Heliocol Solar Panels; Aquamatic Cover; Legend pressure-side cleaner with Hayward booster pump; TF100 Test Kit.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: Cold this morning, solar valve opened?
    You should be able to select solar freeze protection on or off in the Easytouch menu.
    Here is the manual see page 43: http://www.pentairpool.com/pdfs/easytouch8and4UG.pdf
    Mark
    jjslinger's Avatar
    Sep 2011
    Santa Rosa, CA
    97
    Thank you Mark.
    I went into the solar menu. Solar was enabled, as well as freeze protection. So, I set both of those to off. Does that sound right?
    I swear I shut off the solar a few months ago, but I think it was a different menu. Maybe I just took solar heating off the scheduling, but it was still "enabled". I'm having trouble understanding the Easytouch programming. The system seemed to work fine until this morning; the pump and cleaner would come on at the programmed time, and nothing ever came out of the (opened) hose bib for the solar panels. So I guess the explanation is that freeze protection came on for both the pump and the solar valve, so water shot out the hose bib.
    Thanks again,
    Don
    Mar 2011
    441
    Quote Originally Posted by jjslinger
    Thank you Mark.
    Thanks again,
    Don
    Usually when I winterize a solar system I disable the valve so this type of stuff cannot happen. Usually can you just flip the toggle switch to off, on the operator, or unplug it.
    20X40 30,000 gallon gunite pool
    jjslinger's Avatar
    Sep 2011
    Santa Rosa, CA
    97
    Quote Originally Posted by racket
    Thanks, racket. That seems like a good idea, given that I don't understand the Easytouch programming too well yet (obviously). I'll have a look next time I'm down in the equipment shed and see if something like that is possible. I think I have programmed the Easytouch correctly at this point, but I don't know how to test it, I guess I just have to wait for it to get cold again and see if it works. Your way is more foolproof.
    Don C.
