Thread: Plumbing vent pouring out water
    Hello Newbie to the site. I have a pool/spa plumbing problem that I can't figure out. Simple plumbing system with caretaker 99 floor care. One valve for directing suction from spa or pool main and one valve for directing discharge to caretaker 99 or spa jets. Here's the problem: my system has a vent line that come up next to the caretaker distributor and has started pouring water out at a fairly rapid rate when using the care taker. If I shift the discharge to the spa jet -- it will stop. The vent is about 12 inches above ground and has a 180 degree "U" on top. I have searched the internet for a plumbing guide for this system, but none show a vent. Any ideas? Thanks
    DaveCook
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Plumbing vent pouring out water
    The vent is probably the air inlet for the venturi spa jets. This is what adds the air to the spa jets. However, water should not be coming out when the in-floor is on unless the spa valve is partially open, then it might although it would still be odd. Somehow water is getting redirected to the spa jets while the in-floor is on. Check all the valve settings to make sure the water isn't being redirected toward the spa.
    Mark
    Mark -- that does make sense. I'll check the valves. Also it just occurred to me that there is a check valve in the system that maybe not closing completely. Thanks, Dave
