Thread: New to Pools/New Pool
    Jul 2011
    Broken Arrow, OK (Tulsa)
    295
    Our pool was just finished by our pool builder, and it was filled on January 8th.
    Our PB told us we probably won't have to add any chlorine to the water for a while, as he put a floater in to handle chlorine delivery until the weather warms up enough for the SWG to kick in.
    Here are our levels, as per the TF100 kit (note: if anything looks "wonky", I would chalk it up to this being my first use of the test kit, and the first time testing a pool!):
    pH = 7.5
    FC = 8.5
    TA = 170
    CH = 310
    (Sorry....CYA didn't get tested, as I didn't think frostbite on my arm was worth the test results...LOL).
    PB hasn't added salt yet...he said salt won't go in for another month or so. I know he's added acid 3 times, and bicarb at least twice since the water went in...maybe more often when I wasn't here.
    16 x 31, Approx. 12,000 Gal Freeform IG pool; Flagstone coping; Quartzscapes Super Blue plaster finish; Tanning ledge w/2 bubblers; 1 HP Pentair Whisperflo pump, Pentair sand filter; (2) Pentair Intellibrite LEDs w/controller; Easytouch8 w/IC-40 SWG; Salt finish concrete decking.
    Jul 2011
    Arizona & California
    805
    Re: New to Pools/New Pool
    It would be interesting to know (if you are willling to post) what your tap water readings are, and compare with the pool water now.
    Jul 2011
    295
    I should be able to test the tap water in the next day or two, and will post the readings.
