Thread: Correct water level?
    Dec 2011
    Gold Coast, Australia
    57
    Hi all,
    Just wondering if there's a "correct" pool water level for a skimmer to work most efficiently? I have an auto leveller and after a recent downpour filled the pool to the brim, I plugged the overflow so I could watch carefully how it's slowly levelling out (the auto-leveller is about 5 metres from the pool so it there may be a couple of cm variance to allow for). Ultimately I'd like to keep the pool as full as possible after it rains to keep the weir door from banging too much. Just wondering if it can be TOO full for whatever reason? Picture below shows the current pool level which is probably where I'd like it to be (the skimmer opening is not perfectly level), but the next pic of the auto-leveller shows that it still has a cm or so to drain before it's level, so it will always drain below the current level. That's OK if it needs to be be lower for efficient skimming etc, but I'll have to do something if I want to keep the water level at it's current level. We're in Australia, so no main drain, just the skimmer.
    [attachment=0:1f4xg96a]IMG_1623-1.JPG[/attachment:1f4xg96a]
    [attachment=1:1f4xg96a]IMG_1628-1.JPG[/attachment:1f4xg96a]
    37000 litre, concrete, pebble, Viron P300 pump, Hurlcon VX7T SWCG, Viron CL-400 Cartridge filter, Solar heating, Pandora Smart Robotic cleaner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Correct water level?
    Yes, it can be too full. High water causes poor skimmer action in cleaning the surface of the water. Normally you want the water slightly past halfway on the skimmer opening.
    Dec 2011
    57
    OK thanks. Looks like it might be pretty much spot on if I leave everything as is and let it drain out the auto leveler.
