Thread: how to check pump for damage
    Last night the temperature dropped below 32 and my freeze protection turned on. Great right!?
    Well...we had a big rain the day before and I backwashed to get water level down. I forgot to put the filter back to "filter" so when I woke up this morning I heard the pump running. Went outside and water level is below the skimmer and pump has been running.
    Not sure how long the pump ran, but I am wondering if there is any damage and how to check for it??
    Roseburg, Oregon
    IG indoor 24000 Gal. Plaster/Gunite
    No Pump (on the to buy list)
    No Heater (on the to buy list)
    Sand filter
    Pool has been out of service since 2009
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: how to check pump for damage
    The easiest way is just to refill the pool and see if the pump works. Your main concern would be heat warping the housing or impeller, meaning you will have flow issues or leaks.
