Thread: Chemicals:Nevada Winter, New pool
    Jul 2011
    Las Vegas, Nevada
    139
    We finished and filled our pool in mid October 2011 and haven't been doing much except maintaining the pH and chlorine. It seems almost to be too simple. I have been adding acid about every three days to keep the pH down and it seems like no matter how much chlorine I add, it hardly even shows anything on the test. How important is chlorine in the winter? I don't want to waste money on something that isn't needed. We have used the spa 3 times since we filled it and the pool once for about 20 minutes. Right now the water temps are about 45 degrees so I wasn't even sure if I would need chlorine since it is so cold. Once the water warms back up above 50 deg I am going to add salt and get the chlorine generator going, but for now we have just been adding liquid chlorine.
    Jay...12,500 gallon freeform pool and attached spa w/ Bullfrog Oscillator & ClusterSpray Jetpaks
    Jandy 2hp VS pump(main), Jandy 2hp Stealth pump(Jetpaks), Jandy 1hp Stealth pump(water features) Jandy CL-580 filter, Jandy Watercolors LED lighting, Jandy Aqualink RS8(revision MM) w/Aquapalm, Autelis Controller, Onetouch controller, Jandy Aquapure 1400 SWG, Jandy LXi 400k heater, Paramount PV3 6 zone infloor cleaning system
    MattM's Avatar
    Jul 2011
    San Diego, CA
    299
    Re: Chemicals:Nevada Winter, New pool
    Hmm....I started up my new pool 3 weeks ago....initial temp was 60 degrees, within a week it fell to 50 degrees due to winter weather before the solar, cover, and heat pump got installed. Regardless, I noticed CC's rising within just 2 days and even with 1 FC in the pool...essentially, even if you don't see it, if you have a good test kit that checks for CC and CC is above 0.5...than you're already behind the ballgame and algae is forming. You don't want to let it get established. On the other hand, if your water temp is staying under 50....maybe you'll be lucky...but I'd still monitor the CC value daily and if it is anything but zero, start to put chlorine in....although avoid shocking for whatever number of days your pool builder suggests (likely 10-14?) as shock can raise ph.
    24K gallon inground gunite/pebble sheen pool, 34'x16' 4-7.5ft deep, 750sq ft solar, pentair ultratemp, intelliflow vs+, ic60, intellichem w/ acid pump, quad de 100, intellibright 5g, intellitouch i5-3s with Screenlogic2, 3" primary piping - 2.5" at equip pad, auto switched deep heating and main returns, automatic safety cover w/ electronic lock and embedded recessed undertrack, sealed stamped concrete deck, dolphin deluxe 5, started up December 2011.
    Jul 2011
    Las Vegas, Nevada
    139
    I am 3 months in and should be able to shock it but haven't have a need to yet. Only when it is windy does anything ever get in the pool but since I live in a desert it is only a few small leaves. My CC has always been at 0
    Jun 2011
    Long Beach, CA
    2,790
    What is your CYA level? For now I would raise it to 40 if it is below this. If your CYA is low the sun will still burn off the chlorine even though it is cold. If you do have CYA and you are not holding chlorine then you probably have nascent algae and will need to follow the advice on how to shock your pool in pool school. Once your pool temp is up, you will definitely want your CYA to be around 80 in Vegas.
