Thread: Cold Climate Solar Panel Winterizing
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    For owners of solar panels who live in cold (freezing) climates, do you take down your solar panel runs for the winter or do you just thoroughly drain and leave up. I seem to recall people stating they drain/leave up but I noticed the Fafco booklet says to take down.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Cold Climate Solar Panel Winterizing
    I have Fafco SunSaver and Revolution panels that are mounted on the roof so they stay up but my local solar installer comes by and removes some pipe end caps and makes sure they are drained. However, I'm not in as cold a climate and only have a few days a year below freezing.
    Jul 2012
    CA
    240
    Can i ask, is that procedure included when you bought solar or is there a small charge every year? thanks.
    25k I/G ecostar ccplus Polaris plaster
    Mar 2007
    San Rafael, CA USA
    12,082
    Small charge every year. If one wants to do it oneself, one can. You just shut off the system and remove a few caps at the bottom of some of the panels to allow full draining and then reverse the procedure for spring opening. I just don't bother getting up on the roof to do it and I like them coming out and inspecting the panels for any issues during spring opening.
