Thread: Tangled cord
    Mar 2010
    Houston
    37
    Tangled cord
    I have a Polaris pressure-side cleaner and this winter, while in the cold water and under the solar cover, the cord is becoming tangled. It has several anti-tangle swivels on it and has never had the problem before.
    Thoughts? Ideas?
    Houston
    ~20,000 inground plaster pool
    1.5 HP Hayward
    Sand Filter
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Tangled cord
    A wild guess - the cord is less flexible when the water is cold, so it's not able to untangle itself as easily as when the water's warm.
    With the solar cover on, do you still need to be running it? It seems like the pool would stay pretty clean.
    roysteves's Avatar
    Dec 2011
    Roseville, CA
    29
    Re: Tangled cord
    If the hose is tweaked when you get the cover off, stretching it out to its full length and letting it dry in the sun a day should help straighten it back out. That can happen if it's stuck in a particular position, especially cold, for a long period.
    Roy Steves - CMO, PoolSupplyWorld.com
