Results 1 to 8 of 8
Thread: Wish me luck
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Wish me luck
    Towards the end of summer, every once in a while when I started the pump manually, I'd just catch a glimpse of a squirt of water by the pump. Never lost prime, no puddles. Around the time of our huge windstorms, the pump started getting noisy. I've been a mechanic long enough to know the sound of a bad bearing. It's still pumping okay, still not losing prime, still not leaking. I let the holidays go past. Now it's time to wrestle the thing out from where it's entrapped by the maze of piping and deal with it.
    Fortunately, it looks like I can detach the pump and motor from the housing. This means no cutting pipes. Not sure how I am going to get the thing up and over all the piping yet....
    Anyway, that's on the schedule for tomorrow. The water's been maintaining its balance quite well, so I'm dosing it good before I shut it all down.
    I'll probably let the local independent pool store do the work. While I do have gear pullers and die grinders and access to a hydraulic bearing press at work, right now time is more important than money.
    Feb 2008
    Denton, TX
    5,061
    Re: Wish me luck
    Good thing that you are getting to handle this issue in the off-season. Good luck!
    Dec 2010
    San Diego, CA
    1,137
    Re: Wish me luck
    Good luck Richard!
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    22,543
    Re: Wish me luck
    There's no doubt that you'll handle it like the professional you are! It'll be a lot easier than getting to some of those auto parts you've surely dealt with.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Wish me luck
    Good luck. Take/post pictures! I'm pretty sure the group loves pictures.
    Dec 2010
    San Diego, CA
    1,137
    Re: Wish me luck
    X2 on the pics please!
    Richard320's Avatar
    Jan 2010
    18,967
    Re: Wish me luck
    Pictures wouldn't have been too exciting. Plus the request came after it was out.
    But, I did get lucky. It came apart quite easily, no seized bolts or anything. And it didn't weigh as much as I'd thought, either. So it wasn't a big deal lifting it out.
    When I went to the pool store, they were watching crimestoppers or something like that on TV. Not the busy season. Not even close. The guy said it would be done today, he'd call. He called maybe an hour and a half later, said the noise was a rock caught behind the impeller, so all he had to do was re-seal it. Under thirty bucks! I woulda guessed the seal kit would be at least twenty!
    So, back home, wrestle it in position, bolt it up, reconnect the wires, and go. It works! The whisperflow is whispering again. No water spraying out anywhere, either. I'll have to wait until tomorrow to see if the ground around the pump is dry, as the ground was still wet from disassembly and I wasn't terribly careful when I filled the strainer basket. Let us hope my luck holds.
    Dec 2010
    San Diego, CA
    1,137
    Re: Wish me luck
    Got my fingers crossed for you!
