Thread: 15 month payback switching from a single to dual speed motor
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello all,
    Looking for your comments.
    I currently have a single speed 3/4 hp 115v motor. Looking at swapping in a dual speed 3/4 hp 115v motor.
    Looks like the payback period will be about 15 months. ($20 month savings). I don't have any water features.
    Currently my pump is putting out about 50gpm.
    My turnover time is about 6 hours. I'm looking at running at low speed for 12 hours. It looks like it would be a monthly savings of about $20.
    The new motor is about $300 installed that how I came up with 15 month payback.
    Anything that I'm over looking?
    2 speed hi = 50 gpm so low would be about 25gpm
    hi run time 6 hours so low would be 12 hours
    electric cost .14 cents KWH.
    Motor I'm looking at 12.4 amps high (cost $1.20 (6hrs) day)/ 2.2 amps low ($0.43 (12hrs) day) (monthly $35.94/$12.75) savings of $23.10
    I would save the current motor for a backup or possible sell on eBay.
    22,553
    Re: 15 month payback switching from a single to dual speed m
    I'd figure a few hours a week on high just to be safe but that's still a pretty good payback.
    mas985's Avatar
    Pleasanton, CA
    11,742
    If you are going by the motor label ratings, then the cost may be a little high. The motor will usually draw less than the label ratings which are maximum limits. Plus, the power factor has to be taken into consideration.
    I don't have any data on the P2RA5D-180L but I do for the similar PHK2RAY6D-101L which will use about 1114 watts @ 47 GPM on high and 280 watts @ 24 GPM on low speed for CEC Curve-A. So that would be $0.93/day for high speed and $0.47/day for low speed using the same run time.
    I also would agree with Bama in that you tend to run at high speed for at least a couple of hours a day to help the skimmers.
    Mark
    Apr 2011
    Murrieta, CA
    2,360
    The specifics for my setup:
    Model PEA5D-180L/ Model P2RA5D-180L and I came about those models because I have C105-92PS/C1-216P impeller/diffuser.
    I currently have a B2661 New Centurion 3/4 HP motor 11.2 SF AMPS 1.67 SF
    and looking to replace it with a B2981 New Centurion dual speed motor 12.4/2.2 SF AMPS 1.67 SF motor.
    @ Mas I'm using Pump tools v002. PE5C-180L is the pump I think is closest to mine.
