Results 1 to 12 of 12
Thread: light out, now how to fix it ?
    hey guys, moved into a house with an inground gunite pool 4 months, the light was out when we got here and i am wanting to fix it before summer. let me explain what i have done so far, had a local pool company come over and look at the pool when i got here and they said i need a whole new fixture and shot a price of $500 to fix the light. i told them i would wait until this summer before i made a decision on the light. so i go and pull the light out of the pool and the canister is completely dry, but the bulb is out, i put another bulb in and the light still wouldnt work. the breaker box probably 75 feet from the light, and there is a electric cord coming out of the ground by the box and they have had it tied into a timer below the breaker box, and the timer has to plugged in, i have tried to plug the timer in and rotate the timer to get the light to come on but it doesnt, where do i go from here ?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: light out, now how to fix it ?
    Do you have access to a voltmeter?
    i dont john, does the wire coming out of the ground below the breaker box and screwed into this timer, does it sound like that is the pool light wire ?
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    I believe I would get an electrician (as opposed to a pool company) to check out the timer and the light. Could be a problem with either one, or the wiring from the pool to the termination point. I had similar problem several years ago and it turned out to be a problem in an underground junction box. I paid the pool company to replace the light and it still did not work. To make a long story short when I finally got fed up with pool company and called an electrician he found the problem in about 15 minutes. I could have saved myself several hundred dollars by calling the electrician first.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    38,290
    There should also be a deck box somewhere near the pool with wire connections ... those connections could also be bad. The wires should run from the pool light through a conduit to the deck box (this conduit is full of water). Then another conduit with wires from the deck box to a GFCI (outlet or breaker). Mine has a third conduit from the deck box to a switch on the house. The switch, power from GFCI, and pool light connections are all made in the deck box.
    Given that you do not have a voltmeter, I too would probably recommend talking to an electrician if you have not dealt with electrical wires before.
    When we bought our house, I checked all this wiring and found that the pool light was not GFCI protected ... it was connected directly to a round fuse panel. I then added a GFCI outlet at the pad and ran the power to the light off of it.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,694
    Quote Originally Posted by jblauert
    Or if you aren't in a hurry (summer is 6 mos away) post a picture of the breaker box and the timer. and maybe we'll see something simple that might get the light working.
    Factory Warranty Station for:
    never got the light fixed, gona get it done before this swimming season, i have looked all over for a deck box and i cant find one, could they have just burried the cord and run it from the light to the breaker box ?is a deck box a must ?
    Jun 2011
    Long Beach, CA
    2,788
    If you can't find a deck box then most likely it doesn't have one. With my pool they just ran all the lights to the equipment pad and had the junction box installed with all the equipment.
    Do you have a volt meter yet? You can pick one up for less than $15 from the big box stores. If you are not comfortable working with electricity then you should just hire an electrician as electricity kills very quickly or pay the $500 for a new light.
    Dec 2012
    Manassas Park, VA
    207
    I also bought a house with a pool and couldn't figure out how to get the light to work. In my case there were two things I needed to make sure were turned on. There was a breaker that needed to be turned on, this was located in a box next to the equipment. There was also a switch on top of an electrical outlet next the breaker box that controlled the light once the breaker was turned on. It was very small and was very close to the cover that flipped over the outlet. After finding that and pushing it to the other side the light came on.
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    Jun 2011
    Long Beach, CA
    2,788
    Without a volt meter you will not have any idea of the problem.
    The first thing is to make sure that the light has power going to it. If it does have power, then the fixture needs to be replaced since you already replaced the bulb. If the light is not getting power then the power at each junction must be measured until you find where the power stops flowing.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Do you have a transformer with your light? My original transformer had a fuse in it. It was tough to see had to use a mirror to see it. Cleaned the contacts it was good to go for a season. The contacts ended up going bad, ended up replacing it with a new powersupply/transformer. Works great.
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Quote Originally Posted by ping View Post
    ^^^^ This. Checking line continuity should be the first concern.
