Thread: Heater on salt water system
    Sep 2007
    middle tennessee
    38
    Am getting ready to add a goldline salt water system to my above ground pool..
    my question is ,,would it be best to add it before,,or after it goes thru my
    heater?,,or would it make any difference,,,thanks
    Above ground 24'round-vinyl-14,000 gal,,1 speed-2 hp pump, 250 lb sand filter ..heated,,salted,,lighted,,decked,,with slide and pool rover jr.....
    TFP 100,,am doing the BBB thing...Wet is Wild!
    Jul 2007
    Brisbane, Australia
    874
    ideally you should have it in parallel with your water heater
    in case you add it before, high chlorine concentration will damage your heater core eventually,
    and if you add it after - high water temperature coming out of the heater will decrease your cell life.
    Typically the SWG cell goes after the heater on the return going to the pool (not to the spa, if you have a spa). Plumbing in parallel has advantages, but is impractical for all but the largest residential installs because of insufficient flow rates and added complexity.
    Guest
    Goldline recommends it be plumbed after the heater, much like an inline chlorinator would be plumbed.
