Thread: Pump wiring....
    Pump wiring....
    I bought a used pentair challenger pump... The wiring diagram on the side shows where to hook up the 2 lines inside the pump casing... So I did so.... However it does not show where the ground goes.... The way the other owner had it was wired back out the back casing and screwed to the bolt on the outside of the pump.... I thought this bolt was for the bonding?? Or do they both connect there... It just seems if they both connect there then the bonding wire would be more like a ground since it will connect to the house through that wire...
    Any suggestions??
    20x40 vinyl liner IG pool, 20x16 shallow end, deep end is 8ft....Metal walls... 1hp single speed Pentair Pump..... 24" sand filter... build in progress....
    Re: Pump wiring....
    In the picture below, you can see a green screw on each pump. The ground goes to the green screw. The outside bonding lug is for the bond wire.
    Support the site
    Re: Pump wiring....
    Ok awesome!! Thanks... Mine is like the one on the left...
    Re: Pump wiring....
    Hi Guys,
    I have a Hayward pump that looks as the right model, I´ve changed the bearings and remove the centrifugal mechanism but at the time to assembly again the start system, it seems like is missing some support for the normally close contacts I don´t remember how the contacts has to be installed in the base, my question is, do you have a picture underneath the mechanism?
    I will appreciate your help
    Brs
    15x34 Moroccan Leisure Pool -rectangle
    17,100 gallons
    SWG-Pentair-IC40
    Clean and Clear Plus-Flow Rate 120-4 filters
