Thread: Did I just damage my new sand filter? (hooked up backwards)
    Oh my, I'm feeling a lot of anxiety right now. So please forgive me if what I'm typing is hard to follow.
    I just finished hooking up my new Hayward sand filter. I'm usually very meticulous about things like this but somehow I hooked up the plumbing backwards. I ended up running the filter for maybe 1-2 minutes before I noticed that sand was blowing out of the pool. Not realizing what was going on, I stopped the pump, set the valve to backwash and when I turned it back on the water was barely coming out. I knew something was wrong, so I turned off the pump and checked the plumbing and it was reversed. What a boneheaded mistake but I was so anxious and excited about this that I had a lapse in judgment. I will go to Lowes tomorrow and get more plumbing supplies and correct my plumbing error.
    I'm really concerned about my sand filter. Did I damage the laterals or the valve with my plumbing error?
    Pool Size: 8600 gallons - rectangle 12'x24'
    Pool Type: Inground with vinyl liner
    Filter: Hayward Pro-Series S244T - 300# Sand Filter
    Pump: Astral Pools IGP2010 - 1HP
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Did I just damage my new sand filter? (hooked up backwar
    Not likely.
    Quote Originally Posted by JohnT
    Not likely.
    Thanks JohnT!!!
    I'm glad my boneheaded mistake probably won't be a costly one.
    I've just finished the replumbing and I'm letting the PVC cement finish curing.
    Just a follow up, that everything seems to be OK now and working as it should.
    SW Indiana
    9,198
    You may find it still blows sand in the pool for a while when you restart it.
