Thread: Pool Pilot Dig-220- replaced cell + cord, purifier = 1%
    My last cell and cord became burnt/rusted so I replaced them both. After installing the replacements and going into the "installer menu" to "replace cell" the digital display says that the purifier is "off" and it's set to 1%. I cannot raise it by pressing the "up" arrow. Why? I can place it into Boost mode but I'm not sure if that actually does anything if the purifier is set to 1%.
    FWIW, I know the "up" arrow button works just fine since I can use it to navigate the menus.
    When I run the test mode the Pool Pilot displays: SC-36, cell power 2, 3000 ppm salt, 18v 6.4A, 55 degrees F.
    Thanks for any help,
    Phil
    13,000 gallon fiberglass pool
    Auto Pilot - Pool Pilot Digital SWG
    S.R. Smith - Turbo Twister slide
    Aquabot - Turbo T Jet cleaner
    Jandy - CS250 cartridge filter
    RayPak - CR206 gas heater
    Pentair - WhisperFlo 1.5 HP pump
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Pool Pilot Dig-220- replaced cell + cord, purifier = 1%
    The water might be too cold for the cell to operate. Check your manual and see if it shows what the water temp should be for the cell to function.
    Love TFP? Become a
    TFP Supporter!
    Thanks, I checked the manual and it says it considers the seasonal temps between 50-90 and then auto adjusts the purifier if it's warmer or colder. So 55 degrees shouldn't cause any issues. Once I determined that, I decided to kill the power to the Pool Pilot and then restore the power. Once I did that, the purifier reading displayed 100% (so I guess my constant "up" pressing yesterday did cause the level to increase but the display just wouldn't indicate it). Power cycling seemed to correct the behavior so it looks like it's all good now.
    Ft Lauderdale, Florida
    1,455
    The Automatic temperture compensation will automatically increase and decrease the Purifier % output, based on water temperature changes. As it goes down to 55 degrees or colder, it goes to a 1% maximum output. As temperatures increase, it will also allow you to increase theoutput higher than 1%, although there will max limit, depending on temperatures.
    Cycling it shouldn't affect the temperature compensation feature, and was most likely a result of the water temperature reading higher than 60 degrees.
    In MOST cases, the temperature compensation works perfectly, and will still provide sufficient chlorine production during winter months... on an unheated pool. If it's heated, the output should not decrease much from the normal operation.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
