Thread: Grecian In Ground Spa Leaks
    My +- 25 Year old in ground (surrounded by concrete and brick) Grecian acrylic spa is leaking about 2" per day...... This is not good..... Probably from around the plumbing inlets or outlets that penetrate the side walls of the spa.....or perhaps from the light.....
    Ideas for economical repair??
    Recommendations for contractors who can quote said repairs in the LA area??
    Thanks.....
    Pentair: Intelliflow VF "Variable Flow" Filter Pump, Compool to Easytouch Upgrade, Easytouch Indoor Control Panel for 8 Circuit System, FNSD48 DE filter on FiberClear, Multiport Valve Kit 2", Mastertemp 300K BTU heater, IC40 Salt Chlorine generator. (2) Jandy NeverLube 3 Port Valves with Pentair XCVA24T Actuators. - Old School 15' X 35' X 9' In-Ground Plaster Pool, Grecian "The Pandora" 838C In-Ground Spa.
    South Central NJ
    3,192
    Re: Grecian In Ground Spa Leaks
    It is likely the gaskets around the jets, skimmer, and drain have deteriorated. The shell will need to be lifted out and all the gaskets replaced.
    Scott
    Owner of - PoolGuyNJ LLC
