Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Hayward Ecostar Variable speed pump, ??What speed??
    Im really confused about what speed I should be running my Pump (%) for maximum efficiency. My pool is newly built and I would like to take advantage of the cost savings of the variable speed on my electric bill , but not sure what my GPM are and I'm very confused about figuring it out.
    Thank you for any help http://www.troublefreepool.com/posting.php?mode=post&f=5#
    22,550
    Re: Hayward Ecostar Variable speed pump, ??What speed??
    Tell us more about your pool and equipment. That way we'll have an idea of where to start, but basically you pick a speed and if it keeps the pool clear then back off a bit and keep doing that until it doesn't keep the pool clean and bump it back up a little.
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    Like Bama said, we need more info to help, there are a lot of factors to consider.
    Basically, your starting point is enough GPM to turn over your pool in a day. From there, you need to make adjustments on based on your pool, did you get enough flow for good skimmer action. Additionally, did you get enough flow to support your heater, solar or SWG assuming you have of those. Next quest is what other features do you need to support, like a cleaner, a spa, water features etc...
    In the end, it may not be the cheapest the pump can run, but its the cheapest your pump can run to support your pool's needs.
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    thank you for your response, is there a formula to figure out GPM?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Here is what I have in the Hydraulics link below. It is rough guestimate.
    Variable Speed Pump Flow Rate Approximations
    The following formulas use the affinity equations to yield a very rough estimate of flow rate.
    1.5" Return Line with 1 x 1.5" Suction Line:
    Intelliflo Flow Rate (GPM) = RPM / 47
    EcoStar Flow Rate (GPM) = RPM / 48
    Plumbing Head (ft)= 0.0167 * GPM^2 - CEC Curve A
    1.5" Return Line with 2 x 1.5" Suction Lines or 1 x 2" Suction Line
    Intelliflo Flow Rate (GPM) = RPM / 44
    EcoStar Flow Rate (GPM) = RPM / 45
    Plumbing Head (ft)= 0.0140 * GPM^2
    2" Return Line with 1 x 2" Suction Line
    Intelliflo Flow Rate (GPM) = RPM / 37
    EcoStar Flow Rate (GPM) = RPM / 38
    Plumbing Head (ft)= 0.0093 * GPM^2
    2" Return Line with 2 x 2" Suction Lines or 1 x 2.5" Suction Line
    Intelliflo Flow Rate (GPM) = RPM / 35
    EcoStar Flow Rate (GPM) = RPM / 36
    Plumbing Head (ft)= 0.0083 * GPM^2 - CEC Curve C
    2.5" Return Line with 1 x 2.5" Suction Line
    Intelliflo Flow Rate (GPM) = RPM / 34
    EcoStar Flow Rate (GPM) = RPM / 35
    Plumbing Head (ft)= 0.0074 * GPM^2
    2.5" Return Line with 2 x 2.5" Suction Lines
    Intelliflo Flow Rate (GPM) = RPM / 33
    EcoStar Flow Rate (GPM) = RPM / 34
    Plumbing Head (ft)= 0.0069 * GPM^2
    If you want something that is a bit more accurate, I will need the following:
    Pump Make/Model
    Height of pump relative to the pool water level
    Diameter and number of individual suction pipes from the equipment to the pool
    Diameter and number of individual return pipes from the equipment to the pool
    Diameter of return eyeballs
    Filter type and backwash valve model if known
    Filter PSI reading at the desired valve settings and pump's highest speed setting.
    Optional: Pump suction reading (in-hg) - not necessary but improves accuracy
    Heater - yes or no
    Pool/Spa valve - yes or no
    Mark
    Thanks mas985
    Pump Make/Model Hayward Ecostar
    Height of pump relative to the pool water level 18"
    Diameter and number of individual suction pipes from the equipment to the pool 2 1/2" main drain 20', 2" skimmer 48'
    Diameter and number of individual return pipes from the equipment to the pool 3 returns 1 1/2" 60'
    Diameter of return eyeballs 3/4"
    Filter type and backwash valve model if known 175sf Hayward cartridge
    Filter PSI reading at the desired valve settings and pump's highest speed setting. Filter PSI reading at pump's highest speed is 20psi
    Heater - yes or no NO
    Pool/Spa valve - yes or no NO
    some pics of the pool
    mas985's Avatar
    Pleasanton, CA
    11,737
    Just to confirm, do you actually have three separate return lines going from the equipment pad to the pool. Normally it is one line that is split at the pool. With 1 1/2" pipe it makes sense that there would be three but I just wanted to confirm.
    With the suction though, I assume those are two separate lines going from the equipment all the way to the pool.
    Mark
    pics
    only 1 line for the 3 returns, and separate
    2 1/2 for main drain
    2" for skimmer
    Thank you for responding back Mark
    pic
    mas985's Avatar
    Pleasanton, CA
    11,737
    With 3 separate return lines, I get a filter pressure around 20 PSI but with a single return line, I get a filter pressure of close to 26 PSI. Something isn't quite right. From the drawing it looks like the returns are separate pipe. Unfortunately, the drawing is not high enough resolution so I can't zoom in on it.
    Mark
    definitely a single return line
    should i let the pump run on full speed for a few minutes before i read the psi?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Can you take a picture of the equipment pad?
    It also looks like you have a waterfall and bubblers. Are those on when you read 20 PSI?
    Mark
    pic
    pic
    pic
    all the water features are off with the 20psi reading
  20. Back To Top    #20
    mas985's Avatar
    Pleasanton, CA
    11,737
    Are you sure that line from the SWG does not split into three underground near the pad? You didn't happen to take a picture before the pipes were covered up?
    Anyway, assuming the 20 PSI is correct and represents the actual return head loss, the flow rate should be around RPM/29 or 118 GPM at full speed.
    Mark
