Thread: how to keep the heater from coming on everytime filter runs
    dissfigured's Avatar
    Oct 2011
    Denton, TX
    51
    I have the hayward equipment and Goldline controls.
    Ideally, I would like to work so if I turn the heater off on the wall controls, it stays off until I turn it back on.
    But I have to remember to go out to the actual heater and pt it on standby otherwise the next day when my filter turns on and goes to spa mode, the heater will kick on.
    I just got a massive gas bill because I clicked the heater button on the wall controls and turned the filter off.
    The next day it ran its course, and the heater came on.
    What is the purpose of a system that errs on the side of the heater being on forcing you to manually turn it off versus the opposite way?
    Thanks.
    In-ground, SWG, 20,000 Gallons, Attached spa w/ Spillover, Hayward system, Cartridge Filter.
    Dallas TX
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: how to keep the heater from coming on everytime filter r
    Do you have an AquaLogic? You should just be able to press the heater button on the main control/remote and the heater will go offline (manual mode). When you want to turn on the heater, you just have to put it back into automatic, again at the main control or remote.
    Mark
    Ft Lauderdale, Florida
    1,455
    you can always set the thermostat at a lower temperature, like 50, so it doesn't come on.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    If you have a pool spa combination, typically you need not program the spa to operate daily. In most cases the pool filtration(pool mode) will circulate the spa enough to keep the water clear.
    Factory Warranty Station for:
