Results 1 to 13 of 13
Thread: Pump/filter mixing brands...
    I am about to put in a new pool... Saving every penny possible... ... Someone is filling in their pool and I can get a Hayward sand filter for about $50... If I delet the sand filter from my kit I will save $350... However, my pump will be a 1.5hp Jandy... Does this matter? Will it cause problems when hooking everything up? Also what should I look for buying a used sand filter...
    Thanks!!!
    20x40 vinyl liner IG pool, 20x16 shallow end, deep end is 8ft....Metal walls... 1hp single speed Pentair Pump..... 24" sand filter... build in progress....
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pump/filter mixing brands...
    No it won't matter.
    Thank you!
    22,539
    The biggest thing you need to know is what size is the sand filter. Also you may be able to save some on the pump too. 1½ hp is a pretty big pump. What size and type pool are you putting in? You should certainly consider a 2-speed pump, 3/4 or 1 hp should be plenty big.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    It's a 20x40.... 8ft deep... The filter I'm getting is coming off of a 18x50... So we pretty close in size.... And the sand filter is 24".... He also has a pump... But he doesn't know if he wants to sell that yet.... Not sure what size it is.... If I get a new one... Should I go with the 1hp? I don't know if they offer a 2 speed??
    South Central NJ
    3,192
    Drop the HP to no more than a 1 HP with a 24" sand filter.
    Scott
    Owner of - PoolGuyNJ LLC
    22,539
    Definitely get a 2-speed if you possibly can.
    Apr 2011
    Murrieta, CA
    2,360
    concur go with 2 speed.
    Ok thanks!!! What are the benefits of 2 speed?? Turn it down at night or during the winter?
    Quote Originally Posted by PoolGuyNJ
    Scott
    Ok thanks! I will take your advice!
    22,539
    The biggest advantage of a 2-speed pump is that you can run it most all the time on low and just switch to high for backwashing and/or vacuuming. That way you save a lot of electricity over running a single speed.
    South Central NJ
    3,192
    Keep in mind though that with a 2 speed, the flow switches for heaters and salt cells may not close and erosion feeders may not capture enough flow due to lower pipe velocities to properly feed sufficiently.
    Scott
    Ok guys... Thanks!! I appreciate it!
