Thread: Autopilot DG-220 pump motor replacement
    I just installed a new Hayward replacement pump motor. When I flipped the breaker back on to power my system the DG-220 came on and my pump came on. Now the pump runs all the time and I can't turn it off with the DG-220. Any suggestions?
    Ft Lauderdale, Florida
    1,455
    Re: Autopilot DG-220 pump motor replacement
    Check and make sure the DIG220 is still programmed to run the pump. Did you change anything in the pump wiring internally?
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Jan 2012
    340
    Did you remove the wires from the autopilot when changing the motor? If you did, sounds like when you re-wired everything you wired the pump back up to where the power comes into the unit and not where the unit gives power to the pump.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
