Originally Posted by WshnIwslofn
I have the same problem with my Down East Hot Tub (1 pump, 4 button, 1100 model) running constantly.
It is killing our electric bill. Please Help!!!
15K gallon salt water pebble bottom pool with attached spill over spa. Hayward 3/4 HP 115/208-230v Northstar Pump, (2) Hayward 2 HP 208-230v Northstar Pumps (1 for waterfall, 1 for spa jets), Hayward T-Cell-15 Salt Cell, Sta-Rite 400K Max-E-Therm Heather, Aqualogic PS-8 with software version 2.43
Can you post the make & model of the control panel that is under the spa?
makes no difference. 4 button topside: push jet then temp, this brings the "f's" up then push temp to scroll through the settings. f-2 runs the pump for 2 hours out of every 12, f-3 runs the pump for 3 out of every 12 and so on. some have an FC which is filter constantly. there you go!!
down east 2004 1 motor.. how do i set economy or sleep mode. pls help seriousbiz2@verizon.net....
look at my previous post for setting modes
the pump running by itself shouldnt "kill" your electric bill, they pull around 3 amps on low. if its heating the whole time its running, that will kill it, but somethings wrong if thats the case.
I purchased this same type of tub (Down East early 2000's with 4 buttons topside. Pump1, Pump2, Temp, and Light) I have been unable to locate a manual online, but countspacula's explaination of the F2-F12 functions have been a great find! I'm trying to find out what other 'tricks' this thing can do. Does anyone have a full manual or explaination of the controls? For example, right now when the 'light' button is pressed, the tub cycles through about 6 colors. Blue, red, green, etc. Is there anyway to keep it set to a single color?!?
Here is what looks like an 04 manual: http://www.masterspas.com/documents/_ma ... Manual.pdf
And here is a 2012: http://www.masterspas.com/documents/_ma ... wneast.pdf
I don't know if either will help, but they might have a nugget hidden in there somewhere!
"I feel most at home in the water. I disappear. That's where I belong."
- Michael Phelps
