Results 1 to 9 of 9
Thread: How to add calcium chloride to a vinyl pool?
    Dec 2010
    San Diego, CA
    1,137
    I have a bucket of hardness increased from Leslie's - which I am assuming is calcium chloride? On the tub it warns against premixing with water and especially not hot water as it says that beat will be released when adding this to water. With a brand new liner I am extra paranoid somewhat is the safest way to add the hardness up. I'll post another thread as I'm having trouble with the CH test but I believe right now I'm at 80 which is surprising because this summer my fill water was 120-140.
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: How to add calcium chloride to a vinyl pool?
    You don't need CH in a vinyl pool. There's no danger of leaching it out of the plaster. Too much CH can still cause scaling, though.
    Dec 2010
    San Diego, CA
    1,137
    Yeah I know...but the warranty specifies certain water parameters being maintained and bumping the CH to the minimum is not a whole lot of CH and as it won't hurt anything either I want to get it in line per their reqs. God help me of we do have a problem and I have to discuss FC/CYA with them as their rec for CL is 1-2 ppm with 40-60 CYA...2 ppm is borderline at 40, and definitely not high enough at 60...
    South Central NJ
    3,192
    5 gallon buck of water, 5 lbs of Calcium. Stir vigorously, wait a few minutes and stir it again. pour around the the pool. Repeat as needed to add the desired amount.
    As Richard noted though, it isn't needed and there isn't a liner manufacturer that would claim a lack of CH caused a failure and get away with it.
    Scott
    Owner of - PoolGuyNJ LLC
    Dec 2010
    San Diego, CA
    1,137
    Thanks Scott!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    it will get warm.
    Dec 2010
    San Diego, CA
    1,137
    I can let the bucket cool down before I add it to the pool...
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    I wouldn't worry too much, assuming its well dissolved, the heat will disperse quickly. You can either slowly pour it in front of a return while its running, or just added it as you walk around the pool. Alternatively, you could just do smaller amount of calcium per bucket, this will reduce the amount of heat created per application.
    With a vinyl pool, you don't need much CH at all (arguably, you don't need any). From your original post, you said your fill is 120-140 CH, that should pretty much be enough? What is your target CH?
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Dec 2010
    San Diego, CA
    1,137
    I'm targeting 200...plus I have this 8lb bucket of Calcium Hardener I bought when we first moved in and I was being pool stored...figured it can;t hurt to raise the CH a bit to get rid of this bucket in the shed...
    I need to rerun the CH test though now that I know I have a floating end point issue. But I expect it to be 120-140 as before. So the 8 lbs is good for about 55ppm which will get me close enough.
