Results 1 to 8 of 8
Thread: Leaves clogging up pipes
    So after returning home from a 13 day trip my pool had a ton of leaves in it. I got the pump primed and working and cleaned the skimmers a day or two later only to find that the pump now can not fully achieve the pressure it needs to properly function. This leads me to believe some leaves and other stuff is stuck in the pipes somewhere. How can I fix this?
    Approx 74,000 liter inground vinyl pool 12x32, laser 225 sand filter, Hayward 2 speed pump + old pool heater.
    Dec 2010
    San Diego, CA
    1,137
    Re: Leaves clogging up pipes
    Try opening the pump and putting a hose in the pump inlet and stuff a wet rag around it to try to flush the leaves back out. Or try a drain king too. You want to push the leaves back to where they came from not towards the pump. Your last step would be to snake the lines. Good luck!
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Quote Originally Posted by carlscan26
    Thanks. I will try that when I get home today.
    Dec 2010
    San Diego, CA
    1,137
    I should add that since you have some flow the Drain King probably won't help - you need high volume to flush that stuff out. But I'd still try it before snaking the line.
    May 2011
    Orange County, CA
    696
    Or, you could use my approach...
    problem-with-cleaner-vacuum-line-t40108.html
    Setting up this reverse flow circuit was somewhat of a pain (but not too bad), but given that we get plenty of leaves in the pool, this permanent approach will ensure that any clogs in the skimmer or cleaner line are a trivial fix.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    Aug 2010
    Dallas, TX
    4,052
    I had the same problem a month ago. I could not generate enough pressure with my water hose to push it back out, so I called the pool company. They used a homemade rig with compressed air and water attached at the same time. It looked pretty simple to build, going to think about it and do something like it next time I have an issue. It made a lot more pressure than my hose alone could. They also had some sort of fitting at the end of the hose that was similar to a drain king but was specifically built to seal off the area rather than to suddenly send strong jets of water into the system. I need to find out what that was, too.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    ...homemade rig with compressed air...
    Got to interject at this point. PVC should not be used with compressed air. Charging/discharging stresses the PVC, which fractures when it fails, and under compressed air, can fail explosively. Seriously - REALLY explosively.
    So after using the drain king on both skimmer lines I was stumped and ready to take apart the pump itself and rebuild. Right before shuting down the pump last night I stuck my hand inside to feel for any debris in the impeller and found a little bit so pulled it out. Turns out that little bit was causing all my problems, now it works great. Next I have to figure out how to get the gurgeling sound to stop comming from my sand filter, bleeding the air does not seem to work. Thanks for all the sugestions guys.
