Results 1 to 16 of 16
Thread: I might be Crazy?
    I might be Crazy?
    We live in Wisconsin and my wife wants to be able to use an IGP all year. I have some idea's but I thought I would see if any of the experts think it is possible. This will be new construction for home and pool and we are going to have Geothermal Heat for home so the loop will be installed if it makes sense to heat pool with same. Oh yea it's damm cold most of the time.
    Cheers,
    Patrick
    Building year round use outdoor in ground pool in Wisconsin
    30,403
    Re: I might be Crazy?
    Hi, Patrick,
    Welcome to the forum.
    The amount of energy required to heat a pool is stunning compared to heating your home. You would need FAR more btu's to keep an IG pool swimmable in Wisconsin than you might think.
    As a btu rookie, I had visions of heating my pool with a whole house wood heater.......there were not enough trees in North Carolina to do what I wanted!! Granted, I have a very large pool but the energy required is enormous.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Perhaps a dumb question, but are you referring to an enclosed IGP or one fully exposed to the elements?
    I've seen several people here in northern Ontario (ie: cold) with IGP's used all year but they are enclosed in a pool room, an IGP open to the elements isn't gonna happen, well, I guess it could but man, you'd have to throw a tremendous amount of heat at the thing.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I think it will be cheaper to find a hotel with a pool in Palm Springs and send your wife there for 6 months out of the year.
    Dec 2010
    San Diego, CA
    1,137
    But could you trust the water?
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    You guys are TOTALLY missing the point here!
    May I be the first to congratulate your wife on her (as yet to be incorporated into the design)...............enclosed hot tub.
    My condolences to Rocksolidfloors.
    Support the site
    Dec 2010
    San Diego, CA
    1,137
    Pretty...
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    If you haven't built the pool what about an indoor pool. It would certainly, increase the cost of building it, but should help with the heating costs of the pool.
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Nov 2011
    Moberly,MO
    1,010
    Find a heating and cooling guy that is extremely knowlageble in geothermal before you do it. Water is the hardest thing to heat. Had a friend built an enclosed pool it was going to take 22 wells to do the pool alone. That was in Missouri
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    I have given up on the geo-thermal and will go with a high output natural gas heater. I am leaning towards an icf pool with an Aquashield enclosure. I would like to put the equipment in the basement since I can run all the plumbing under the footer of the foundation easily before I pour the basement floor. Is there a major problem in doing that? And also do I run the PVC lines below the frost line from both the suction and return directly from the pool.
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    You can certainly run your equipment in the basement, but if the pump and equipment are below the pool level, I would be concerned about any leaks especially big leaks. You better have a lot of sump pumps hooked up in your basement when you run into water issues. You'll also have to add more valves for any maintenance since gravity will be working against you.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    How far down will you assume frost level? I live in a very similar climate and it can reach 6 feet here, I know people that have dug 6' pillars for decks and they've still heaved.
    The pump in the basement may be a concern, especially if remotely close to anything electric. Working with your pump could see water spray in the basement, I know my pump handling has caused spray out sometimes, you'll have to account for losing some degree of water.
    Nov 2011
    Moberly,MO
    1,010
    You also will probably want an auto cover to help retain the heat in the pool. Wouldn't recommend pump in the basement unless pool surface is below that. Although basement swimming might be the new indoor pool
    The frost line is about 4' and yes the pump will be about 5-9 ' feet from the bottom of the pool. If I do not put the pump in the basement than I guess I would need a heated outdoor room for the equipment since I plan to run year round.
    Hi -- curious if you picked aquashield as a vendor, and if so how is it working out?
    Thanks!
