Thread: Help with draining
    Help with draining
    I have a basically new pool (4 mo.) with a CLI aggregate finish. Shortly after the pool was done, some areas in the deep end around the drains began showing "thin" areas of aggregate. Anyway, the plaster contractor could not explain what was happening and advised me to drain the pool so they could diagnose and repair the areas in question. Neither he nor the general pool contractor said anything about hydrostatic floating of the pool when draining. Is this something I should be overly concerned about? I'm in Austin, TX, with very rocky soil. Thoughts?
    Mike
    9500 gallon plaster/gunite pool w/waterfall, 1/2 HP 1sp pump, 120 sq-ft Cartridge Filter, 336 sq-ft EPDM Solar Panels, CPSC16 SWG, Boratized
    South Central NJ
    3,192
    Re: Help with draining
    Ask the PH if the installed any hydrostatic plug or valves. Often they under the drain covers.
    Scott
    Owner of - PoolGuyNJ LLC
