Thread: Interface Hayward ecostar and jandy controller
    Would like to know if any one knows how to interface the Jandy RS 8 to a Hayward ecostar pump?
    20x40 gunite inground roman shape 7 ft deep end, 1hp hayward main pump, 2hp in-floor cleaner pump for Paramount PV-3,all plumbing 2" sch 40, Nitro wall climber robot, Fiberstars WPC-2, ColorLogic LED lights, Hayward 425 sq. ft. cartridge filter, UltraPure UPP25 UV ozone.
    South Central NJ
    3,192
    Re: Interface Hayward ecostar and jandy controller
    How old is the RS?
    Scott
    Owner of - PoolGuyNJ LLC
    10 years old
    South Central NJ
    3,192
    That's going to require a main board and firmware upgrades. And even then, I am not certain it can talk to a Hayward VSP. A Pentair or Jandy's own, yest but I don't know.
    Scott
    mas985's Avatar
    Pleasanton, CA
    11,743
    This may not be what you are looking for but you could just connect the EcoStar as you would a single speed pump via a relay and then use the EcoStar internal timers to control the speeds at different run times. If you want full control of the EcoStar speeds from the Jandy controller, I think that is going to be a problem.
    Mark
