Thread: Strange skimmer, gizmo won't fit. What to do?
    Oct 2010
    Eastern TN
    172
    I purchased a gizmo with attachment to blow out my lines. My skimmer has two openings in the bottom that are eccentrically placed. The gizmo's neck is not long enough to allow it to screw in as the wider part of the gizmo hits a plastic rim that is too close to the return opening. I don't have a pool store near me. Is there some sort of threaded extension that has a male and female end that will raise the gizmo an inch or so? Why would there be two openings? Do they come from the factory like this or did my installer drill the holes? Fortunately we haven't had many nights below freezing and the days are around 50 degrees but I am getting concerned about properly winterizing.
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Re: Strange skimmer, gizmo won't fit. What to do?
    If you could post a picture of the skimmer openings that may help us figure out what you need.
    Love TFP? Become a
    TFP Supporter!
    Oct 2010
    Eastern TN
    172
    I'm out of town until Tuesday. I will get photos asap. I was afraid that this was an odd situation.
    Oct 2010
    Eastern TN
    172
    Finally got around to photographing. I did not expect to have all of this water in the skimmer with a solid cover. It got below freezing a few nights last week. Now I'm really worried about possible freezing damage.
    Link to photo: http://gallery.me.com/goodbeach
    What are the odds of cracking having occured and what can I do now with gizmo? I did just pour rv antifreeze in the skimmer.
    Dave
    22,551
    They make a 'skinny' version of the gizmos. You should be able to use it if not then just pour some antifreeze into the pipes.
