Results 1 to 17 of 17
Thread: Magnetic Stirrer
    Magnetic Stirrer
    I have heard a few things about using a magnetic stirrer while testing the pool water. I use a Taylor test kit. Please explain to me how a magnetic stirrer works and if it is worth purchasing? If it is, where is the best place to purchase one? Also, are there other things you have to purchase to use it.
    Thanks for your help!!
    East TN
    13,000 gal San Juan Fiberglass Pool;SWG; GoldLine Pro Logic Controls
    Hayward Sand Filter; Hayward Max-Flo XL Pump;Polaris 380; Hayward ColorLogic LED
    Raypak Gas Heater
    30,431
    Re: Magnetic Stirrer
    Keep in mind I have an agenda in that I sell the stirrer. When they first were introduced by Taylor, I thought they were gimmicky and I had little interest.
    Repeated positive reports on this forum prompted me to reluctantly try one for myself.....I loved it after the first set of tests. Every test you perform in the graduated cylinders is quite a bit easier and the stirrer gives you a quicker, more precise endpoint.
    It is probably worth its price alone in how nicely it assists the endpoint of the CH test. I would buy another tomorrow if mine broke today.
    Jan 2011
    Richmond, Texas
    595
    I agree with duraleigh. Using the magnetic stirrer makes testing much easier. It was money well spent.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Nov 2010
    Calera, Al
    271
    I have one and it is a great tool... In any test you perform that requires stirring/swirling it alllows you to perform the test more accurately and quickly. Especially the CH test if you were to have hard water! While not necessary it is a tool that will make your life much easies in the persuit of correct pool water chemistry blance. absolutley the best purchase I have made for my pool behind the TF100! It is one purchase you will not have buyers remorse for!
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Thank you for the replies! So do you just put your test container on the magnetic stirrer and turn it on? Do you need to add a magnetic bar? Do you add the drops while it is "stirring".
    Thanks!!
    East TN
    Raypak Gas Heater
    Nov 2010
    Calera, Al
    271
    Quote Originally Posted by creechy
    Thanks!!
    Yes, put your water in the cylinder to the proper level, then drop in magnetic bar and place on the stirrer cradle and turn on. You can add drops while it is stirring... it is pretty slick and very easy...
    MattM's Avatar
    Jul 2011
    San Diego, CA
    299
    It's very useful when you have a long test which requires stirring for every drop and you have 10+ drops....just put the vial on the stirring motor, drop in the magnet, and set it to on and it keeps on stirring while you focus on counting your drops and watching color.
    24K gallon inground gunite/pebble sheen pool, 34'x16' 4-7.5ft deep, 750sq ft solar, pentair ultratemp, intelliflow vs+, ic60, intellichem w/ acid pump, quad de 100, intellibright 5g, intellitouch i5-3s with Screenlogic2, 3" primary piping - 2.5" at equip pad, auto switched deep heating and main returns, automatic safety cover w/ electronic lock and embedded recessed undertrack, sealed stamped concrete deck, dolphin deluxe 5, started up December 2011.
    donaldm823's Avatar
    Cape Coral, FL
    147
    I bought one 2 years ago-best money I ever spent for Taylor titrations. I use it with TA and CH Taylor tests since they are drop by drop. The US Navy used them for mixing their samples when sampling their various systems. Very reliable and mix the sample with little air intrusion. It's a simple glass beaker within a magnet the size of a Tylenol capsule that gores in the beaker with the water. It couples with the stirrer base and goers round and round with variable speed control
    Don SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter, Pentair SWG, Pentair Intelliflow VS pump (11018)
    FAFCO solar panels w/Pentair SolarTouch controller
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
    Mar 2010
    Spring, TX
    1,082
    Everything that you need comes with it. You get the batteries, metal bar, and the little machine that you set the cylinder on. I have used the cylinders that came with my tf100 kit with no problems. I have used other ones as well. I believe it comes with its own cylinder, but correct me if I am wrong. But so far anyone that fits on there will work just fine. I put my water sample in the cylinder and drop the bar in. Sit it on the machine and turn it on and add drops as needed based on the test I am doing. It makes testing that much easier and you dont have to worry if it got mixed well as it does it for you. So I have not had to retest anyting due to loss of water or thinking maybe that result was wrong. It is useful as others have said for CH, but could also be very useful if you have to shock. I use it for every test I can though and love it. I can do a full set of testing in about 5-10 minutes depending on how slow I am moving and if I can get the right sample size the first time w/o going over or under.
    It is the best purchase you will make right behind the testing kit. I would say right with the testing kit, but without the testing kit you would really not need the stirrer.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    SW Georgia
    300
    I agree with all the above. I would not do without mine.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    May 2011
    Coral Springs, FL (near Ft. Lauderdale)
    93
    A definite must-buy. Makes everything much easier, especially testing at night since the base lights up so you can see the color of the water being tested. Also, you should consider the Taylor 6190 Samplesizer. Makes getting the right amount of water into the tube a no-brainer.
    Check out Hot Tub Warehouse for your supplies - great prices: http://www.hottubwarehouse.com/Taylor_T ... s/1974.htm (no affiliation - just a satisfied customer).
    15x30 inground concrete pool w/spa and spillover, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter and Hayward Navigator V-Flex
    Jandy AquaPure 1400, Laars LX400 propane heater w/120 gal above-ground tank
    Jandy VS FloPro 2.7 HP Pump VSFHP270JEP; FlowVis FV-C Flow Meter
    Jandy iAquaLink and OneTouch controller w/PDA remotes; JVA for draining pool
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by HofstraJet
    You can also get it from David aka duraleigh as well from their site. Provides outstanding customer service and super fast shipping
    http://tftestkits.net/Sample-Sizer-Meas ... l-p65.html
    It may be a little more, but he is always on this site and just a phone call or email away and will always help you out no matter what.
    Thank you so much for all the feedback. I ordered one from David and it arrived today! I can't wait to try it. I noticed many posted that they use it for CH and TA testing. Should I use it for chlorine and ph testing?
    Thanks!!
    East TN
    Raypak Gas Heater
    Richard320's Avatar
    Jan 2010
    19,055
    Thanks!!
    I use mine for everything but pH. I bought more stirbars off eBay (Taylor charges a fortune!) and I had an extra tube from an older test kit, so I'm set. I can run all the tests before I have to dump things out and do the dishes.
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    +1 great device very handy. One tip, put fresh batteries in it when you get it, it seems to resolve a lot of minor annoyances with the device. Chlorine test is the most common test I use it for. For pH I still use the comparison tubes.
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Thanks again. I love the magnetic stirrer! I also like the idea of getting some extra testing tubes so I do not have to stop and rinse after each test. One trip to the sink would be great!
    East TN
    Raypak Gas Heater
