Thread: Physical size of this check valve?...
    Oct 2011
    Orlando, FL
    77
    Can anyone tell me the length of this check valve, from tip to tip? I want to plumb this in, and am trying to determine if I have enough room.
    It is a Jandy 7305 check valve, the 2 inch, straight model:
    http://www.bestbuypoolsupply.com/jandy- ... alves.html
    Thank you!
    Mike
    9500 gallon plaster/gunite pool w/waterfall, 1/2 HP 1sp pump, 120 sq-ft Cartridge Filter, 336 sq-ft EPDM Solar Panels, CPSC16 SWG, Boratized
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Physical size of this check valve?...
    Don't have one on hand but the dimensions I see online have it at 8.8" long. I would have guessed 8" so that seems right to me.
    Support the site
    Oct 2011
    Orlando, FL
    77
    Thank you. That's actually a little smaller than the one I am replacing, so I have the room.
    Sure do appreciate it.
    Mike
