Results 1 to 10 of 10
Thread: Any thoughts on hardwood leaf stained water.
    6000 gallon dog therapy pool (plaster). My plastic cover blew away and the pool got fouled with quite a bit of leaves before I returned. October) I've fished them out; running the 60 gpm pump (cartridge) 2 days. Can't seem to get the discoloration out of the water. Tannic acid, I suppose. Can't use anything that dogs can't drink. Any thoughts? Dumped in 6 gal bleach. Immed before that, ph was at 7.0.
    got broken dogs waiting for the pool.
    PS 4 feet of water is color of weak iced tea.
    Bill
    29,000 gallon, concrete pool and spa, SE PA
    Jandy 2HP pump, Raypak 400 heater, Polaris 380
    30,403
    Re: Any thoughts on hardwood leaf stained water.
    Chlorine will remove the stain. It may take longer than you want (days) and it may involve more chlorine than you want for your dogs (what's your cya level?) but chlorine is the answer.
    My only other thought is a non chlorine rapid oxidizer like mps available at pool store but I do not knopw for sure that will remove the stain.
    Thanks Dave. There's only a little CYA left in there. I'm trying to lose it because it can under some circumstances cause kidney stones for dogs. thanks for reassuring me, I'll just keep the pure chlorine high and keep cleaning the (10 micron) cartridge. Sorry for the incomplete chemistry report, but the chlorine is so high right now that the normal tests aren't working right. (I don;t let anyone in till the chlorine drifts back down to 3 or 4.) Its easier for my application to work without CYA; Its easier to add bleach than to get dogs to not drink.
    This morining, its the color of lime gatorade.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Lime Gatorade might be a low level algae. Sounds like tea is clearing up. I'm thinking you might need shock the pool. A complete set of test results number would help especially FC and CC.
    Thanks Bobo. My instincts are like yours, but I'm way beyond normal shock. Still can't get any coherent readings. Can't believe its algae, even though the residual from the leaves is indeed green in tint. The 60 gpm pump has filtered the entire 6000 about 30 times in the past 2-3 days. Just tried the short chlorine test and the test vial turned deep orange/red. I'll do the long test after lunch, but strongly suspect it is way, way high.
    Confirming: FAS drip test: >40 ; CYA < 20
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    How expensive is water? Maybe a drain and refill is the cheapest & quickest solution.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    rural/well pump. It'll do it, but its hard on the gear to deliver that much water. I'll give it a while longer, I've stalled my patients till after the holiday at this point. I can always dump it if necessary.
    Apr 2011
    Murrieta, CA
    2,360
    Use distilled water and mix 50/50 in your test container that may get you into the ball park.
    Further research: the vacuum head in the bottom of the pool is showing white. Its the white plaster that is dirty, rather than the water. Overall, it gives the clear impression that the water is green. But it is dirty plaster that is causing the impression. I drained a few inches to be able to see the plaster clearly around the top edge. I am proceeding with the shock level bleach (actually quite a bit above shock level), along with some brushing and filtering, until someone might have addtional suggestions. I suppose I could dump the water and treat the plaster with full strength bleach. I suppose the operative decision is whether to wait for the pool water to eventually clean the plaster or empty it, clean it, refill.
