Thread: He changes the water ONCE a year
    Dec 2011
    So. Cal
    14
    I know this old fool who has a spa & don't change the water but once a year. He says the water is clear and he balances it. But ain't that a dirty dirty thing? He says he puts his greasy body in it at least 3 times a week. Ugh.
    Dream Maker Big EZ Spa
    Using Leslie's Chlorine, Spa Shock, Ph Up & Dry Acid
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: He changes the water ONCE a year
    At least he changes it. I've seen horrible things...
    roysteves's Avatar
    Dec 2011
    Roseville, CA
    29
    It can be quite unsanitary, actually. I recommend spa owners change their water about every 3 months.
    During regular spa use, non-organic contaminants (like perspiration, body oils, personal care products, sunscreen, and worse) will build up in the water. Letting these byproducts, referred to as Total Dissolved Solids (TDS), accumulate in the water will cause sanitation issues. This will then lead to you spending more on chemicals to compensate, or it becomes a little like a giant petri dish.
    Changing your water every 3-5 months is generally a pretty good idea.
    Roy Steves - CMO, PoolSupplyWorld.com
    30,414
    Fatcatdj,
    Do you actually KNOW his age? He may be 26 and has spent too much time in that tub!!
