Thread: Aqualink Freeze Protection and Solar Panels
    So we have aqualink rs and every time the freeze protection goes on the water goes through the solar panels and now we have a huge leak on our roof. How do we find the change the flow to avoid the solar panels?
    Thanks!
    22,542
    Re: Aqualink Freeze Protection and Solar Panels
    Post a pic of your setup and we should be able to point you to the valve if there is one.
    Here are 2 pics. If you need a shot of something specific let me know. We are very grateful for any help.
    Mar 2011
    Hazelton, PA
    57
    Both pipes going to the roof have ball valves. Close both of them. (one has broken wings). Where do you live?
    Dec 2010
    San Diego, CA
    1,137
    Probably the best thing is to disable the Solar heat and freeze protect programming.
    If you close off the ball valves but the pump still runs with the automated valve turned for solar you'll dead head the pump so you also need to disable the automated valve that sits between the pipes that go to and from the solar. Under one end of that valve actuator is a three way switch. When the system is not sending water to solar, put that switch in the middle position which will deactivate it.
    Once you fix the leak flip the switch back. If you put it the wrong way then water will flow to the panels when not in solar mode - just flip the switch the other way.
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
