Results 1 to 11 of 11
Thread: Intellichlor IW40 - No Flow
    Newbie to pool ownership and this board. Flow led is solid red indicating no flow. Checked the blades and they are virtually spotless. Power light is green, cell light is blank, life light is green. Salt level lights alternate blinking between check salt and low salt. Pool temp is about 45 degrees. I'm fairly certain the flow light should be green. Did I mention I was a newbie? All this stuff is greek to me. Can someone point me in the right direction of what I need to do to get flow? Thank you. [attachment=1:11tikzj6]photo2.JPG[/attachment:11tikzj6] [attachment=0:11tikzj6]photo1.JPG[/attachment:11tikzj6]
    28,500 Gallon; Pentair Quad DE80; Pentair Easy Touch 8 & 4 Control; Inground Pebble Tec; 160 GPM Max; Polaris 280; I hate my pool; More aggravation than enjoyment.
    Re: Intellichlor IW40 - No Flow
    So I am also a newbie, but are you sure you have the pump on? Also, you might make sure any valves that divert water are bringing your pump flow through the salt water generator. If it turns out that the pump is not on, but the SWG is on you should consider having it rewired so that the SWG is not on unless the pump is on. Hope this helps!
    17'x36' Freeform (Omni/Gemini shape) Polymer Vinyl Liner Pool; Made by Hydra Pools; 6' Water Depth; Cantilever Concrete Stamped Coping; 8' Radius White Step; 8' White Cozy Cove with 6 Jets; 1.5 HP Pentair Whisperflow 2-Speed Pump; Pentair Clean and Clear Plus 420 Cartridge Filter; Kreepy Krauly Legend Pool Sweep; 2 Skimmers; 4 Returns; 2" Rigid PVC; Pentair 5G LED Light; Pacific Ultra Mesh Safety Cover; Pentair Intellichlor IC 40; 3 Deck Jets
    One more note - I believe the IC40 SWG from Pentair stops functioning properly in cold weather conditions. This might be a reason why the flow light is on...
    Mar 2011
    Hazelton, PA
    57
    You might have a bad flow switch
    Yes, the photos were taken with the pump on. There is a zero pressure reading on the air relief valve which I assume is because there is no flow. Could cold weather conditions be the cause? Shouldn't the light still be green?
    I just tried opening the manual air relief valve on my filter and starting the pump. No water stream shot out of it which I assume is because there is no flow and no pressure. Am I on the right track?
    Oct 2010
    Pensacola, FL
    67
    I had a similar problem with "no flow" on the IC40. I checked the salt cell and mine too was clean and clear. I noticed that my water level had dropped a few inches. Added enough water to return it to a level above the middle of the skimmer. Problem went away.
    Bill Moyer
    CWO4 USN (Ret)
    Pensacola, FL
    10k gallon 12x24 in ground pool built 2008, vinyl, Pentair Intellichlor IC40, Pentair Intelliflo v/s pump, Hayward sand filter. Using the BBB method.
    Thanks but my pool is full.
    SCCS's Avatar
    Sep 2008
    Left coast
    79
    Quote Originally Posted by Kimbovi
    Then for some reason the pump is not pumping water. And the pool is full of water. Do you have a valve closed on the inlet side of the pump?
    16,500 gal Roman end with PebbleFina finish
    4 x 160 intelliflo pump
    Easytouch controls with an IC40 chlorinator
    Sta-rite cartridge filter
    A & A infloor cleaning system
    Pentair 5g LED pool light
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Have you recently opened your pump to empty the basket? Sometimes in reassembling, the lid o-ring becomes dislodged, or some debris gets in between the o-ring and the lid, or the o-ring and the groove, and will prevent the pump from achieving prime. It doesn't take much. I've seen a small leaf, the size of a pea, kill the systems prime!
    Factory Warranty Station for:
    Mar 2010
    MidCities, TX
    9
    I have several inputs for your comment above:
    1) manually open all your valves, and return them to their previous position. This is to create a 'rapid current' so that the flow sensor of IC40 can recalibrate itself, especially at a cold temperature.
    2) did you check the salt level? if low salt, then IC40 is disable. (The photos don't show IC40 produces any chlorine.)
    3) what is the pump speed (rpm)? if rpm is set at a slow speed, then IC40 might not detect the flow.
    Hope these help.
    19,000 gallon, irregular kidney shaped, plaster pool surrounded by (8) cypress, (1) oleander, (3) palm trees, (2) unknown shrubbery
    Pentair Tagelus 100D sand filter, with fresh #20 silica sand, and WhisperFlow 3/4 hp. full rated pump
    Innovative Pools controls with digital timers and remote light switch
    Hayward pool sweep with new gearbox A-Frame & turbine, and pods
    TFP's resident Pool Fool :)
