Results 1 to 8 of 8
Thread: Vegas_DP
    Vegas_DP
    Hi from Vegas. Thought I might intro myself. We had a pool/spa built over the winter 14k gallons free form. The pool has been full since January and we use the spa every weekend. Warmed the water and been swimming when temps over 90 here. We have had no problems yet. I have been using the "PUCKS" so far but ordered an Aquarite SWG Friday. The CYA is about 30 now so time for the pucks to stop.
    I went to the pool store to get a base line on my salt (90). The guys there said "The best water we have seen all week". I was quite proud of myself.
    I added 320 pounds of salt and the wife said she can taste it. Going to have the pools store check the level before I install the SWG but I figure its about 2750. Just held back one bag to not overshoot it.
    The pool build can be seen here
    http://www.flickr.com/photos/donpelca/s ... 185417880/
    It is in reverse order. ie after/before cause I am to lazy to fix it.
    See Ya
    14,500 inground gunite
    7' connected spa with overflow waterfall
    Goldline salt water chlorine generator
    Hayward 4 cartridge filter
    Hayward 400K heater
    Completed January 07
    Arizona
    924
    Nice! Congrats on doing so well with your pool. Are you going to install the SWG yourself?
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Thanks.
    I plan on a self install. Wife isn't so sure but the instructions seam easy enough to me.
    Hayward 400K heater
    virginia
    25
    Enjoy the Pool!
    36k, 23'x47' freeform 3.5'-9'deep
    Gunite/white plaster
    Colorlogic LED lights.
    TexasGirl's Avatar
    Central Texas
    95
    Welcome, Vegas.
    Debbie
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    rogerbrks's Avatar
    Round Rock, TX
    172
    Welcome!!! Your pool is awesome. I like the palm trees along the wall. The rocks looks like little maintenance is needed = more pool time.
    21,200 gal IG gunite, CL 580 sqft Cartridge filter, aqua pure salt system, polaris 480-blue&white, Jandy PDA Remote, (4) Jandy Deck Jets
    Quote Originally Posted by rogerbrks
    That is the plan !!
    Hayward 400K heater
