Results 1 to 7 of 7
Thread: Freeze Protection help/Sugestions?
    Dallas, TX
    227
    I have a pool with a freeze protection standalone box that seems to not be working. I really don't want to pay a pool service 80 dollars to come out and tell me it's not working then charge to install one. Is this something that is easily installed with proper safety precautions taken?
    It has been below freezing a few nights this week, and it's not kicking on. it is set at 36 degrees and it was 31 out and the pool was off. Is there a way to test it better, or just assume it's not working. I will take a picture of it later and post it. I know it worked last season. The place it is in gets sun on it during the afternoon, but this was in the morning and it is shady on the box.
    If i do need a new one, any suggestions on a basic, cheap freeze protector i could swap out the broken one for?
    new house: TBDK gal IG plaster pool, filter Titan CM DE filter 36 sq ft , 1.5 HP Pump; Polaris 380
    22,548
    Re: Freeze Protection help/Sugestions?
    Post a pic of it and a model and we'll have a better idea. There should be a temp sensor attached to it and you can ice it and get it to actuate. That's the easiest way to test it.
    Dallas, TX
    227
    No idea what brand it is. any guesses where i can look for that? Was installed when i moved in. Where is the temp sensor to "ice it" How do you do that?
    here are the pictures:
    Inside
    Side
    outside
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    It looks like there is a set of blue and black wires going out the bottom of the box; follow 'em!
    Dallas, TX
    227
    and that will lead to the temp sensor. Pretty sure those go into a silver electrical tube that goes into the timer box next to it (as barely seen in the last picture). What does the temp sensor look like?
    Oct 2009
    3,899
    Oh, I see. There's a dark line in the wall that I thought was the wires going straight down. Well, if you open up the timer box you can at least follow the wires for a little further. Maybe a picture of your equipment would help. Sorry!
    22,548
    That's an ABCO model FP240 freeze protector. Here's the manual for it. There's a capillary tube in the box that senses the temp. If you find it you can take ice in a zip-lock bag and lay on or against it and it should actuate in a minute or less. CAUTION: TURN OFF THE POWER until you have placed the ice.
