Results 1 to 10 of 10
Thread: spa command install problems.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Hi all... Installing a pentair spa command remote by the spa. Wiring has been checked... connection seems good. But when I power on the system and try to assign an id to it, there is no display on the remote, no lights no nothing.
    Any help?
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: spa command install problems.
    Have you tried wiring it to the other COM port? Do you have any other spa controls or COM devices connected?
    You should be getting 15VDC across the black and red wires (terminals 1 and 4) which should at least give you power/light I'd imagine.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Thanks. I will check that.
    I have two pumps, a heater and a screen logic, and a swg all connected to one com port. This was the only thing connected to the 2nd com port b/c the terminal strips I used to connect all that to the other port were full.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    If I don't have 15v dc across those terminals, is there a fuse on board to check? This is a new intellitouch i9+3
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    I'd assume the 15v track is the same for both COM ports, but I'm not sure. The more likely problem is the amount of stuff connected. Pentair makes an expansion COM module (PDF) for $50. P/N 520818. I've never needed one but I also don't recall ever trying to double up on one COM port. Perhaps someone who puts these things in more regularly can chime in. In the meantime I'd try disconnecting everything but the spa command just to see if you got a response from it, then start reconnecting accessories one at a time.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    I know that the old iS10 wouldn't light up (display the temp) till you put it into spa mode. Give that a try...
    Factory Warranty Station for:
    Mar 2011
    441
    Quote Originally Posted by Pool Clown
    The temperature wont display, but the active auxiliary circuits would illuminate.
    20X40 30,000 gallon gunite pool
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    So I checked voltage, its getting the correct voltage, made a short cable for it and connected standing at the control panel.. still dead as a doornail. submitted a warranty request with pentair. Hope they arent as slow as their online reputation....
    The expansion com module is just a fancy terminal strip, so I just used a terminal strip.
    Mar 2011
    441
    I usually just use wirenuts instead of a terminal strip =)
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Well pentair referred it to a local pool guy for warranty call... hopefully I wont have to wait too long for an appointment. Not a huge deal tho, waiting on plumber for gas install still.... sigh.
