Thread: AquaLogic malfunction, getting annoying
    Aug 2011
    Pasadena, CA
    10
    This happened once a few weeks ago, and then again this week two nights in a row. I'll be awakened in the middle of the night wondering what the noise is, and slowly realizing it's pool equipment running when it shouldn't be. And it's all the equipment, booster pump, filter pump, air blower, etc. All the indicator lights on the controller are usually lit up too, including ones that have nothing connected to them. Putting the unit into service mode stops everything, but coming back out of service mode, and it all comes back on. The first two times this happened, flipping the breaker for the controller reset the thing back to normal. However, last night, tripping the breaker (twice) didn't work. So I just left it off for the rest of the night. Busy day and I didn't go check it out yet... I'll see if it comes back on to normal tomorrow.
    Do these units (it's a AQL-PS-8) have a history of random malfunctions that anybody knows about? I'm getting tired of stumbling outside in my pyjamas at 2:00 AM to deal with this thing.
    Eric
    15000-gal IG-Gunite/Pebble, 400-gal spa, Hayward C5520 cartridge filter, Hayward SP4015X20 2 HP filter pump,
    Hayward H400 heater, Ultrapure SPP70 UV ozonator (disconnected), 0.75 HP Booster pump (but no pressure cleaner),
    Polaris 400QT 1.5 HP blower, Fiberstars 6000 lights, Goldline Aqua Logic AQL-PS-8 controller.
    Nov 2011
    Magnolia Texas
    80
    Re: AquaLogic malfunction, getting annoying
    Mine will shut down randomly and then restart sometimes when the salt cell kicks in. Check the back of your ecu to see if there are any burn marks. Mine had one at the K1 solder point. I'd sure like to hear what everyone has to say.
    28,000 gallon salt water pool
    DE Filter
    Inground plaster construction
    1-1/4 hp pump with 1hp booster pump
    Could it possibly be your freeze protection turning on or malfunctioning?
    From the Goldline manual;
    There are several reasons the filter pump may be running at times other than the timeclock
    period setting. These include super-chlorination, spa operation, manual operation, heater
    cooldown, freeze protection and “solar-extend”.
    Of course most of these should show on your display.
    Like Boland01 said, I believe I would check the circuit panel for any burnt or loose connections.
    To do this you should turn off the power breaker (in the house) that feeds the panel. There are 3 ea 11/32" screws to open the panel cover and the plug that goes to the salt cell. Open the panel and check the plug in connections (temp sensors, ecu, display, etc). Check that all electrical connections at the circuit breakers, relays, and especially the white, green and copper grounds are good and tight. If you find a problem or just don't feel comfortable doing this then I would recommend calling an electrician.
    Hopefully it will be a simple fix.
    best of luck,
    John
    "Experience is what you get, just after you needed it."
    Owner DIY build, steel/liner kit, 18x36 Deer Creek, sport depth, approx 17,500 gal,
    Aqua Plus SWG, 1 1/2 hp, 2 speed, 300# sand filter and twin Color logic 4.0s, MX-8 Cleaner.
    My DIY Pool Build
    Aug 2011
    Pasadena, CA
    10
    I hadn't thought about freeze protection, nor did I happen to notice what the air temperature sensor was indicating on the display. That makes sense, as the last few days it could certainly be getting down into the high 30s in the middle of the night. I didn't note it when I went through the configuration a while back, but I seem to remember the freeze protection being set at 38 F, and I believe some of the outputs have it enabled. That being said, if it is indeed freeze protection kicking things on, I would see no need to have freeze protection enabled on the blower. Plastic pumps and pipe make sense. If only that ****ed booster pump wasn't so noisy... guaranteed to wake me up.
    I think I'll check out the electrical connections in any case, just to be sure. I was thinking of disconnecting the ozone generator anyway, so it's a good excuse to open things up.
    Thanks!
    Eric
